FORScan and ABS data logging
Old Oct 21, 2016 | 09:11 AM
blkout50's Avatar
blkout50
Hey everyone!! Will FORScan data log wheel speed, yaw sensors and TCS? My truck is currently at the dealer so I can't connect my copy of FORScan to the truck to verify data logging.
The reason I ask is that my 2016 is currently at the dealer for the right front ABS intermittently activating. Since it is an intermittent problem, the dealer is having difficulty troubleshooting. We have been able to duplicate the problem, but it is intermittent with no repeatable conditions, it just does it randomly.
I found a guy on another forum with an identical problem as I have. I need to capture the wheel speed and yaw sensors and the TCS to confirm that my problem is the same. If the wheel and yaw sensor are normal and the TCS activates, the problem points to the Restraint Control Module (RCM). The yaw sensor is connected to the RCM which is why the RCM is suspect.
Thanks in advance everyone!!
Edit: fixed acronym
Old Oct 28, 2016 | 11:39 PM
blkout50's Avatar
blkout50
Hey everyone!!
FYI, for those interested, yes you can data log Wheel Speed Sensor (WSS), Vehicle Speed Sensor (VSS) and Traction Control System (TCS). I didn't find a Yaw Sensor PID so i could not track it.
Update: My truck is back at the dealer. Convinced dealer to connect their data logger to my truck and capture these items. I was able to capture 2 events with their data logger. Returned dealers data logger for their inspection. While waiting on dealer, I had my truck for a couple of days. Connected FORScan to my truck and set up PID's to watch which are; TCS, LF WSS, LR WSS, RF WSS, RR WSS, Ambient Air Temp (AAT), 2 different instances of Throttle Position and 2 different instances of Brake Pedal. I drove my truck to work following morning and had 2 more instances of my RF ABS activating. Checked data logging in FORScan and found 2 events of trucks TCS activation for no reason, all WSS and VSS are normal. Throttle is activated and Brake pedal disengaged.
Called dealer to speak with SA as a follow up to get the results of their data log. SA informs me that their data logger was empty. They are not sure what happened. When I returned the dealers data logger, it showed that I had recorded 2 events. Not sure what happened(?). Lucky for me, I had my FORScan Data logs. I met with dealers SA and Tech and went over my data logs. Tech agrees he now has enough information to pass on to Ford Engineering. Tech agrees that the RCM is suspect due to possible defective Yaw sensor.
Now it is the waiting game...
In closing, FORScan is a GREAT tool!! If any one is interested I can post screen shots of the data I have that shows TSC spikes, WSS and VSS normal conditions. FORScan also exported the data a as comma delimited file, which is also helpful.
Old Oct 28, 2016 | 11:57 PM
Dakster's Avatar
Dakster
Please post away... I'm interested... Occasionally I have hill START assist activating when it shouldn't.
Old Oct 29, 2016 | 12:02 AM
MPD56's Avatar
MPD56
Thanks for the information.
Is there an actual Yaw sensor and where is it, or does the module do the math from two wheel speed sensors?
Old Oct 29, 2016 | 12:04 AM
blkout50's Avatar
blkout50
Old Oct 29, 2016 | 12:08 AM
blkout50's Avatar
blkout50
Dakster,
Starting at the top;
TCS (notice spikes of TCS turning on)
LF WSS (normal)
LR WSS (normal)
RF WSS (normal)
RR WSS (normal)
VSS (normal)
AAT
TPS1
TPS2
Brake Pedal1 (off)
Brake Pedal2 (off)
edit: forgot to include VSS
Old Oct 29, 2016 | 12:12 AM
blkout50's Avatar
blkout50
My understanding is that the Yaw Sensor is inside the Restraint Control Module (RCM). I don't know that for a fact, just what I have been told.
Old Oct 29, 2016 | 12:21 AM
blkout50's Avatar
blkout50
Here is the data of just the TCS event (I sorted to the top for easy reference). Both TCS activations last about second or so... The first TCS event starts about 10.4 minutes into my commute and the other one about 13.2 minutes.
Old Oct 29, 2016 | 12:31 AM
Dakster's Avatar
Dakster
Thanks for posting it and going through this. Not only will that help you, it could also help others.
Old Nov 2, 2016 | 08:31 PM
carlhwv's Avatar
carlhwv
Originally Posted by blkout50
Hey everyone!!
Do you know which module maintains tire pressure senor information?
Old Nov 2, 2016 | 08:46 PM
MPD56's Avatar
MPD56
I believe that the TPMS module stores the Tire Sensor ID information and the BCM keeps the pressure set point information.
The TPMS module has 10 slots that the programming stores the SN of each pressure sensor. Example Slot #1 is the front left tire. I've been hoping to put sensors in my trialer tires but haven't got there yet( I hear that this can be done on the 2017 model year). Using Torque Pro I setup a display for each tire, this is how I know what tire is having a problem.
Old Nov 2, 2016 | 08:53 PM
carlhwv's Avatar
carlhwv
Thanks for pointing me in the right direction. I'll take a look tomorrow and verify.
Old Aug 31, 2017 | 07:33 AM
monsterx7's Avatar
monsterx7
Solved?
I saw this thread and was wondering if the issue was ever resolved?
(What I did) I don't have a Ford truck but do have a Ford Edge. I also had an issue where the Traction Control Light was coming on randomly. I replaced the Stability Control Cluster (YAW rate sensor) and the symptoms did not change. I then dug into the wiring diagrams to see what was involved (not a whole lot). ABS Module, Stability Control Sensor, Steering Wheel Angle Sensor, and the PCM. After looking at the diagrams I decided to start checking connectors and inspecting wires.
(Result) I found that the ground wire for the Stability Control Cluster (YAW Rate Sensor) was loose and causing the signal going to the ABS Module to be intermittent.
Not sure what your wires are going to be but here are mine in case they cross reference:
Black/Green - Ground
Yellow/Grey - Power (12v)
Green/Orange - HS CAN2+ (data)
Blue/White - HS CAN2- (data)
Old Aug 31, 2017 | 08:52 AM
blkout50's Avatar
blkout50
Yes, problem was solved!
Truck had only 4K miles when the traction control issue started and under warranty. Ford Engineering (FE) instructed my dealer to replace the Restraint Control Module (RCM). I don't know this for a fact, but I was told that the Yaw Sensor is in the RCM and that is why it was suspected of being bad. Replacing the RCM did not solve the problem. Next, FE instructed dealer to check and replace Steering Rotation Sensor (SRC). The SRC fixed my traction control issues!
hth
Old Nov 23, 2020 | 08:34 AM
mewaschuk's Avatar
mewaschuk
Exclamation
where did you find the sensors in the charting setup? what are they called? I'm having this exact same issue and cant find the sensors to add to the log??? thanks !
