Shifter collar replacement
Old Oct 25, 2016 | 11:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Originally Posted by jdgarner13
So that welded bead is missing correct?
Bingo, the key that should be welded to the tube is missing.
Old Oct 26, 2016 | 03:29 PM
jdgarner13's Avatar
jdgarner13
You last comment Mike was exactly what I have been searching for. I couldn't find any info on the actual inner workings of the shift tube. Thanks
Old Oct 26, 2016 | 04:23 PM
jdgarner13's Avatar
jdgarner13
Knowing that now, does a complete replacement of the steering column sound like a better option? I'm willing to try to remove the tube and replace it, but I can't find info on the process.
Old Oct 26, 2016 | 04:38 PM
jdgarner13's Avatar
jdgarner13
When I change gears under the hood, should the tube rotate at the top end? If so, if doesn't. Does this indicate that the lower key is also broke?
Old Oct 26, 2016 | 05:04 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No, probably not. There's a spring at the bottom of the shift tube that pushes up on the tube. With the upper flange unbolted, the spring has pushed the tube up, disengaging it from the bottom shift arm.
This is a picture of the key that's missing on your tube. The lower key looks the same.
Old Oct 26, 2016 | 05:22 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I saw in another post you're wondering how the shift tube is replaced. With the shift collar off, it's relatively simple.
Remove the neutral start switch actuator, it just clips on the shift tube, and pull the tube out. The spring on the end may or may not come out with the tube.
Old Oct 26, 2016 | 05:33 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Let me know whether you have manual or power steering, 2 or 4 WD and I'll check and see if there are any NOS shift tubes available.
Old Oct 26, 2016 | 05:42 PM
jdgarner13's Avatar
jdgarner13
That is exactly what I'm looking for!!!
Old Oct 26, 2016 | 06:35 PM
jdgarner13's Avatar
jdgarner13
Mike you are a godsend. I have power steering, 2 wheel drive. I have a few mechanic friends, but none have ever been this deep into a steering column. They all just changed the whole column out. After I get the shift tube I'm going to take it to work and try to re-tack the key back on. Your advise has been spot on and right on time. Thank you so much.
Old Oct 26, 2016 | 06:50 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I have power steering, 2 wheel drive. Thank you so much.
Not a problem.
Tube, column shift
Fits:
73-77 F100-350 2WD w/ Power steering & FMX, C4 or C6 transmission
C9TZ-7212-E
26 11/16" long
Green Sales, Cincinnati, OH has 1 (800) 543-4959
Dennis Carpenter, Concord, NC has 797 (!) (704) 786-8139
Dennis Carpenter has them for $49.95
http://dennis-carpenter.com/column-s...p/C9TZ-7212-E/
Old Oct 27, 2016 | 04:26 PM
jdgarner13's Avatar
jdgarner13
Alright Mike, semi-per your instructions, lol. I was able to remove the shift tube, but I had to break the neutral safety switch arm in order to do so. It is clamped with locking tabs. I'm taking the time to work and going to attempt to braze or tack the key back on. Here is what I was able to recover from the column. As always thanks so much for your insight.
Old Oct 27, 2016 | 04:34 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Ohhh, you didn't need to do that. There's a hole in the actuator, you insert a small screwdriver in it and pry it off. It'll pop right off. It's not a disaster though, new ones are still available.
As for brazing the key back on, just be advised, the clearance of the key and key way is tight, so you might have to "dress" the braze with a file to get the key to slide into the key way.
Old Oct 27, 2016 | 04:59 PM
  #28
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D0TZ-7B097-B (replaced C5TZ-7B097-A & D0TZ-7B097-A) .. NSS Selector Lever / Obsolete
RED TAYLOR FORD in Corning AR has 3 = 870-857-3518.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1,589 (!) = 800-476-9653.
Old Oct 27, 2016 | 05:03 PM
  #29
jdgarner13's Avatar
jdgarner13
Yeah, it was a tight space trying to get anything in the steering column opening for the actuator. I have already ordered a new actuator. I measured the key and the key and was aware of the tight fit. Do you think JB weld would hold the key in place? My concerns about welding or brazing is the amount of heat needed. I don't want to damage the tube, the wall thickness is pretty thin.
Old Oct 27, 2016 | 05:43 PM
  #30
mikeo0o0o0's Avatar
mikeo0o0o0
Do you think JB weld would hold the key in place? .
You know, I really don't know. My gut feeling is no, there's actually quite a bit of stress on the key when you're moving the shifter.
You can try it, and if it doesn't work replace it with a new one, although for the $50.00 DC wants for a new one, I'd rather just install one that I know will be okay.
My luck has always been, parts that are "iffy" never fail when convenient. They always fail at the worst/most inconvenient time.
