needing some advice
Old Oct 21, 2016 | 05:13 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I did have a some porting work done - CJ-sized exhaust valves, and a bit of hogging out the exhaust ports, especially the air injection boss bumps in the port itself.
I think you're going to be fine.
As for the 2bbl thing, sure, but ... why?
Old Oct 21, 2016 | 05:40 PM
truckguy933's Avatar
truckguy933
I was thinking use it as a 2bbl until I can buy a 650 vacuum secondary, its a 750 double pumper and I agree its a little to large and just gonna waste fuel
Old Oct 21, 2016 | 06:03 PM
krewat's Avatar
krewat
Ah, I agree. I don't see why you can't disconnect the secondaries and do fine.
Old Oct 21, 2016 | 06:04 PM
krewat's Avatar
krewat
Oh, and make sure you wire the secondaries closed - you never know what vacuum will do to the butterflies.
Old Oct 21, 2016 | 07:41 PM
truckguy933
Ya I see that happening taking a big gulp of air like that I think would make pop through the carb
Old Oct 21, 2016 | 08:01 PM
truckguy933
I got the engine installed and broke it in for 30 minutes 2200-3000rpm, changed the oil, and it sounds really good, but it sure does idle alot smoother than I thought it would
Old Oct 22, 2016 | 02:03 AM
truckguy933
My buddy came by today and he brought me a set of rebuilt fe heads, he didnt know I made it this farXD but they are c6aer heads,. Would those be worth swapping out the d2 heads?
Old Oct 22, 2016 | 07:50 PM
Destroked 450's Avatar
Destroked 450
How much gas that 750 uses is how you use your right foot, if you don't mash it to the floor the four barrel wont open.
Old Oct 22, 2016 | 09:44 PM
truckguy933
I wont never know if I can't get this thing tuned right, I been having hell with it, I'm starting to regret this thumpr cam already.. A buddy told about this thumpr cams being really picky with the tune, if I advance the timing any more than where its at, it wont crank when warm and if I advance it with the engine running the idle gets really smooth and you can hardly hear the cam, so the timing Is retarded quite a bit
Old Oct 23, 2016 | 09:27 AM
Destroked 450
No bigger than that cam is you should be able to set the base timing around 9-12 degrees, I've ran some large super stock style cams didn't take over 16 degrees base timing to get them running properly.
If it takes a lot of timing to get it running properly you need to recheck the timing chain to make sure it not off a tooth.
Worked on a friends 351 years ago, it wouldn't idle below 32 degrees timing, cam timing was off a tooth.
Old Oct 23, 2016 | 11:29 AM
truckguy933
Everything is set right, when the motor is running, I can put enough timing in it to where it will die and ditto for retarding it, its pulling about 8-9 1/2 inches of vacuum but if I advance it any more even just a hair theres way to much cranking pressure and the starter wont turn the motor over
Old Oct 23, 2016 | 12:45 PM
Destroked 450
So what do you have the timing set at?
Old Oct 23, 2016 | 07:54 PM
  #28
truckguy933
I have not timed it yet with a gun, to broke to rent one, I tried my best by ear. But I dont think I got far
Old Oct 23, 2016 | 07:56 PM
  #29
truckguy933
But.. I do have a very good hunch the base timing is probable around 7-9 degrees, but thats only a hunch
Gr0ve
Oct 2, 2017 12:45 PM
oldblue31
22
Jul 13, 2009 12:25 AM
stinkfist
Jun 10, 2008 04:42 PM
mongo75
Oct 23, 2006 12:00 PM
okie allan
Sep 5, 2003 03:14 PM
