LED interior light conversion with theater dimming??
Old Oct 20, 2016 | 09:05 AM
AGrayson84's Avatar
AGrayson84
I'm not sure about the second gen Expeditions, but my '06 Navigator has the theater dimming feature when the interior overhead lights come on and go off. My G8 did the same, and I quickly found that LED's flicker as the voltage is very low during the dimming. I know LED's have evolved a little over the years, but has anyone successfully installed LED's without flickering on a vehicle with theater dimming? If so, what's the trick-- a special component, or just a special LED? Would a CAN-BUS LED work for our interior lights? Thanks!
Old Oct 20, 2016 | 03:15 PM
Travis S's Avatar
Travis S
Generally speaking, LEDs' brightness is controlled by current. It can be done by PWM (think microcontrollers) as well, but very low pulse rates (for super low brightness) create visible flickering.
My gauge lights (all converted to LED bulbs) don't flicker at all, regardless of the dimmer position. Might give you some ideas on how to make it work the way you want.
eightOsix
May 6, 2018 05:27 PM
Irish19614x4
All Things Towing
36
Feb 5, 2018 08:15 AM
kralldaddy
2009 - 2014 F150
Jul 7, 2016 07:41 PM
FordmanNJ
All Things Towing
Aug 18, 2015 09:31 PM
BigJake34452
Jan 3, 2010 10:23 PM
