Sponsored by: Real Truck
Winter is coming..
Old Oct 20, 2016 | 06:17 AM
RightWingNutJob's Avatar
RightWingNutJob
I found this telescoping one at Wally-World. (It was a few bucks cheaper in the store than on line.) It's worked fine for three winters, and it's not that expensive. It's long enough (54 inches) that I can stand on the ground and clean off my roof. (Although your experience vary - I'm 6'5".) And it collapses down short enough that you can keep it in the cab instead of in the truck bed (and not have to chip it out of a block of ice). The brush swivels allowing you to push or pull heavy snow. The arched handle lets me reach over and pull snow off of my roof.
I use it mostly to clean off snow, or scrape frost off the windshield. If we get freezing rain, I switch to a heavier dedicated ice scraper.
https://www.walmart.com/ip/SUBZERO-1...4-In./44124093
Old Oct 20, 2016 | 09:00 AM
seville009's Avatar
seville009
Ditto on the telescoping brush. Stand on one side and push it all to the other side to try to keep it from blowing in your face.
For ice, keep a spray bottle of windshield washer fluid in the cab and spray it in the windows; it will stay on and melt it vs getting pushed off by the wipers. Also helps melt the ice on the side windows; especially when the ice prevents the windows from going down.
Old Oct 20, 2016 | 02:23 PM
AZLugz's Avatar
AZLugz
I moved to Arizona, I have seen snow here in mesa twice in 20 odd years
Old Oct 20, 2016 | 03:56 PM
Gangly's Avatar
Gangly
I'm in Houston, what's snow?
Old Oct 21, 2016 | 06:33 AM
RightWingNutJob
After the Houston rains this year, could I interest you in a low mileage set of pontoons and oars?
Old Oct 21, 2016 | 08:44 AM
FordBlueHeart's Avatar
FordBlueHeart
I use a snow broom made by a company called Shuttsco? I have a 5ft wooden painter's pole screwed into it. I guess if you wanted to, you could use a telescoping pole too.
Old Oct 21, 2016 | 02:30 PM
dynamic's Avatar
dynamic
I use a snow brum Manufactured by angel-guard products.
They are readily available at most big box store here in the North east.
mine has been in use for 10+ years and is absolutely awesome.
I keep one in each vehicle as well as one in my house for the early am first clean up.
Old Oct 21, 2016 | 03:30 PM
Desert Don's Avatar
Desert Don
Originally Posted by ExDakotaOwner
So how do you short guys (I'm 5'9) brush off the snow of your SD's?
My little brush barely brushed off my dakota.
A-r-i-z-o-n-a!!!!!!!!!! But then, I am 6'2" so not a problem for mr!!!!!!!!
Old Oct 21, 2016 | 03:48 PM
1979 Ford's Avatar
1979 Ford
It is the white stuff that falls from the sky and causes everyone south of I 70 lose their freaking minds.
I have an extendable scraper with a brush on it.
AXracer
74
Nov 24, 2014 11:23 AM
amdriven2liv
Feb 10, 2014 11:10 PM
LightningRyan
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 26, 2010 01:01 PM
Slow
Dec 5, 2005 03:51 PM
MMills06
New Hampshire Chapter
Jan 27, 2005 11:57 AM
