Keeps over heating
Old Oct 19, 2016 | 11:32 AM
Daniel Anderson's Avatar
Daniel Anderson
Keeps over heating
I have a 1990 ranger 2.9 L 5 speed with over drive. I've tried 3 thermostats. Flushed coolant system compleatly twice sprayed all derby out of radiator front n back. Checked water pump its good. I drive it 5 or 10 minutes and the over flow is boiling and pumps fluid to the ground. Im also compleatly in the red. Help please.
Old Oct 20, 2016 | 11:41 PM
pawpaw's Avatar
pawpaw
Excessive exhaust back pressure from a restriction, like a clogged cat converter, muffler, kinked exhaust pipe, maybe a blown head gasket & or maybe a radiator cap that's not sealing good, & or a fan clutch that's not locking up, are some thoughts that come to mind. Let us know what you find.
Old Oct 21, 2016 | 09:48 AM
tomw's Avatar
tomw
With that engine, I'd be looking for cracked cylinder heads. You can check for CO or CO2 in the radiator using a testing machine that detects its presence. There may be a test strip available that will respond. A surgeons glove stretched over the radiator cap that gets REAL BIG might be another indicator.
If you have access to a 'bore scope' that will fit your plug holes, you can look around without disassembling the cylinder heads.
I think the problems with radiator, pump and clogged converter would take longer than 5 minutes to overheat the engine as much as described, but things vary.
tom
Daniel Anderson
Oct 26, 2016 10:42 PM
98 expo
Jul 16, 2010 11:45 PM
aurgathor
Aug 2, 2006 11:26 PM
TigerDan
17
Jul 24, 2004 11:28 AM
dustinleavitt2000
17
Jun 27, 2003 04:07 PM
