Help me identify this noise?
Old Oct 18, 2016 | 11:59 PM
ch1k3n123's Avatar
ch1k3n123
This exhaling noise happens pretty consistently. Usually doesn't take as many turnovers for the engine to start but that's inconsistent.
Old Oct 19, 2016 | 12:35 PM
r2millers's Avatar
r2millers
Pretty hard to get a clear audio of the noise. Does it usually happen when just cold starting?
Does it continue for 5-10 seconds and then stop?
Does it moan and/or groan?
Last time you've cleaned out your turbo unison ring?
Old Oct 19, 2016 | 12:40 PM
ch1k3n123's Avatar
ch1k3n123
Can't say that it only happens on a cold startup, I can try things out to see.
No it's just the single exhaling noise.
No moaning or groaning from the engine.
I have not cleaned out the turbo unison ring. Is that something I can do myself?
I can try to get better audio with my ICE mic if needed, I was hoping this would be good enough to possibly diagnose some issues. I can definitely answer supporting questions to the best of my ability though.
Old Oct 19, 2016 | 01:13 PM
BLADE35's Avatar
BLADE35
Heater blend door
It's normal I can hear it
The only thing running at that time was a vac pump and it moves the door
Turbo and everything not in play yet at 7 seconds in
Old Oct 19, 2016 | 03:34 PM
navistarnut's Avatar
navistarnut
Thanks BLADE!
I knew I had heard that noise somewhere, durrrr......it's when I drive the kids truck.
His sounds like this about to a "T"
postmaster12
Aug 21, 2023 10:28 PM
08F550
Apr 6, 2014 01:12 AM
Andy's7.3L
General Diesel Discussion
Nov 22, 2013 02:09 PM
shark1979
Apr 5, 2013 09:29 AM
Taylormade2011
6.7L Power Stroke Diesel
Oct 31, 2011 09:50 PM
