Shift problems D1
Old Oct 18, 2016 | 05:40 AM
Maathiu Ra Yin's Avatar
Maathiu Ra Yin
Shift problems D1
If I put it in d1 it revs but doesn't go anywhere. Put it in d2 and i have to slam it all the way down to get it going. Put it in D and it feels like it has first gear. I get a block away and every time, the trans fault light comes on and i get codes p0731 Incorrect gear ratio 1 and p0732 incorrect gear ratio 2. I've been trying to figure out what this could possibly be. I was hoping it was maybe a solenoid but there's no code for the solenoid. If its a worn clutch then why does it feel like i have first gear in drive? When i turn it off, it seems like the computer forgets and has to relearn that it's having a problem. It doesn't store the code and throws it only after driving it a block. I checked all the obvious fuses pcm related. Anyone know why this is happening? I also had some throttle codes so I cleaned the throttle body and reset the computer. The codes didn't come back. I understand this can throw it into limp mode. But after resetting the computer it behaves the same way. The most troubling thing is the no power in d1 but feeling like it has low power in drive. This is after a computer reset and initial start up. I'm about to flush the transmission and clean the lines and cooler and check the valve body for sticking valves. I've been doing a lot of research but can't pin point anything exact about this condition.
Last edited by Maathiu Ra Yin; Oct 18, 2016 at 05:48 AM. Reason: Added information.
Old Oct 18, 2016 | 06:23 AM
projectSHO89's Avatar
projectSHO89
It would be useful if you actually identified specifically what you're working on and which transmission was involved.
Old Oct 18, 2016 | 08:53 AM
Maathiu Ra Yin
2004 f150 new body style Sohc 5.4l 4r75e style side with 6.5' bed takes gasoline and transmission calls for Mercon v...
Old Oct 21, 2016 | 06:07 PM
Maathiu Ra Yin
Must not have been that useful..
Old Oct 21, 2016 | 08:07 PM
steve(ill)'s Avatar
steve(ill)
P0731 FORD - Incorrect First Gear Ratio
Repair Importance Level: 3/3
Repair Difficulty Level: 3/3
Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Shift solenoids
- Transmission mechanical problems
- Transmission hydraulic control circuit
Old Oct 21, 2016 | 08:09 PM
steve(ill)'s Avatar
steve(ill)
I think at a minimum, its time to pull the pan and LOOK.. Might be all kinds of crud in the bottom. If broken parts, your screwed.. If DIRTY, clean pan, clean solenoids ( sticking) and change oil............... ??
Backwoods Beauty Que
1997 - 2003 F150
Dec 12, 2017 08:41 PM
Farmer_Jack_13
Jan 26, 2017 09:27 PM
2bizze
Jun 7, 2013 08:14 PM
Gen3Benz
Dec 11, 2012 11:44 AM
robraz
Oct 26, 2005 10:42 AM
