07 6.0 loud squealing
Old Oct 17, 2016 | 05:53 PM
KEN.WISBY's Avatar
KEN.WISBY
HELLO EVERYONE.
WELL I DON'T KNOW WERE TO START. I HAVE A 07 6.0 AND I NEED SOME HELP. FIRST THING IS I JUST HAD MY ENGINE BULLET PROOFED AND NEW HEADS PUT ON. I INSTALLED A SCT TUNER. WELL ABOUT A WEEK AGO I WAS ON MY WAY TO WORK AND OUT OF NO WHERE I STARTED GETTING THIS HIGH PITCHED SQUEALING NOISE, IT ONLY DOES IT WHEN I REACH ABOUT 12LBS OF BOOST ON UP. WILL NOT DO IT WHEN IN PARK. I TOOK THE TURBO OUT AND INSPECTED EVERYTHING. I DID NOTICE I HAD A LITTLE PLAY IN THE TURBO. ALL HOSES AND BOOTS WERE FINE. CHECKED THE Y PIPE DID NOT SEE ANY CRACKS. PUT EVERYTHING BACK AND STILL GETTING THE NOISE. I ALSO REPLACED THE CAP FOR THE COOLANT. CAN ANYONE HELP ME
Old Oct 17, 2016 | 07:12 PM
jmaskew's Avatar
jmaskew
Check the band clamps to see if they are tight enough. I had a similar issue and replaced both band clamps for the down and up pipes on the turbo and it turned out to be the little one on the egr cooler.
Old Oct 17, 2016 | 08:26 PM
Tideman's Avatar
Tideman
Could be serpentine belt, idler pulley bearing or another pulley bearing. Power steering pump? Shows up when you put a load on the engine. Not a lot of help am I?
Old Oct 18, 2016 | 08:19 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Do you still have the plastic CAC pipe between the cooler and intake elbow? If so, check it closely for cracks in the corrugated section under the air filter.
Old Oct 18, 2016 | 09:01 AM
KEN.WISBY's Avatar
KEN.WISBY
07 6.0 SQUEALING
THANKS EVERYONE. I WILL LOOK AT ALL THESE TONIGHT. ON THE WAY INTO WORK TODAY IT SEEMED A LITTLE LOUDER AND IT ALMOST SOUNDS LIKE ITS COMING FROM UNDER THE STEERING COLUMN.
Old Oct 18, 2016 | 01:30 PM
WatsonR's Avatar
WatsonR
Could be the exhaust manifold, an up-pipe leaking or the flexible coupling. Take a look at the flex joint for carbon or black looking dust.
Also Ken, take the CAP LOCKS off please... kind of hard on the eyes, like I'm reading a Naval message.
Studded07
Aug 3, 2015 06:42 PM
RedBaron134
Mar 31, 2014 02:21 AM
KJNDIVER
Sep 1, 2011 01:43 AM
dirty661
Jan 17, 2010 09:55 PM
There Goes The Neighborhood
15
Dec 23, 2006 07:35 AM
