Turn signal solid... no blinky blink...
Old Oct 17, 2016 | 03:19 PM
Apocalypse's Avatar
Apocalypse
So this is an intermittent issue, it started happening about two months ago and there is no rhyme or reason as to why it started. It'll usually last about an hour or so and then go away but for that hour it is incredibly infuriating! When it does get stuck like this I end up holding my hand on the lever and clicking it up and down so I don't look like I have a busted truck to the person behind me, but I know my timing is way off so it still looks like I have a busted truck. Any ideas what could be causing this? I really don't want to have to go tearing into the dash and trying to find a wire that might have been chafed but if that's what it takes then I guess that's what I'm doing.
Old Oct 17, 2016 | 03:21 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Bet you $10 it's the multifunction switch.
Old Oct 17, 2016 | 03:41 PM
Misky6.0's Avatar
Misky6.0
Or the relay? Have you tried 4-way hazards (I think it's a different relay).
You might be able to swap the relays (if they are the same of course, otherwise, there is often another relay of the same type in there somewhere).
Old Oct 17, 2016 | 04:44 PM
X-Hibition's Avatar
X-Hibition
It's the flasher, or at least it would have been in the old days. Also, are all your bulbs good?
How do I get the ten bucks?
Old Oct 17, 2016 | 05:28 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Let's wait and see what the actual issue is first.
I say its the MFS because i've ran into the same exact issue on Explorer's in the past. The contacts inside get worn out and cause all kinds of issues. That's why I'm pretty sure it's the issue, could be wrong though...
Old Oct 17, 2016 | 09:37 PM
Apocalypse's Avatar
Apocalypse
Is there anything I can check now or am I just stuck waiting for it to do it again? Where is the relay so I can check the connections?
Old Oct 18, 2016 | 08:48 AM
Misky6.0's Avatar
Misky6.0
You should check the owners manual (I think there are links on FTE to where to download them - if you don't already have them)..
Probably in the fuse panel beneath the steering wheel, might even be labeled (not sure I recall if mine are). Some are under the hood.
Keep an eye on eBay for shop manuals for your vehicle(s), well worth it. They'll have wiring diagrams and all kinds of useful info..
Old Oct 18, 2016 | 09:13 AM
Apocalypse's Avatar
Apocalypse
Just wasn't sure if it was in the set under the hood or the dash, I'm hoping it's under the dash
Old Oct 18, 2016 | 12:49 PM
Romanova's Avatar
Romanova
MFS is only $100 from RA, couldn't hurt to start there.
Old Oct 18, 2016 | 06:59 PM
hav24wheel's Avatar
hav24wheel
Isn't the flasher up under the middle of the dash?
Easily reached from under the dash, if you know where it's at. Or others have ripped half the dash apart to find them.
Old Oct 19, 2016 | 12:08 AM
Bently_Coop's Avatar
Bently_Coop
If it is the flasher I removed the OEM head unit and it was back left of it, not to bad of a job.
Old Oct 19, 2016 | 08:10 AM
Vince79vette's Avatar
Vince79vette
I had the same thing happen to me when i was using a trailer. Was a short in the trailer harness. U might have a short in the harness for the rear trailer connector
Old Oct 19, 2016 | 11:01 AM
Apocalypse's Avatar
Apocalypse
Only????????????
Old Oct 20, 2016 | 09:06 AM
Gene Horr's Avatar
Gene Horr
In modern cars it will do this if the light bulb is burned out. Since it is intermittent the most likely cause is the bulb is loose or there is corrosion on the contacts. Since you will be opening it up go ahead and get some new bulbs, clean the contacts and replace the existing.
The flasher tends to be an all or nothing device. It is rarely intermittent (well, other than when working correctly ha ha). But it is cheap enough that if the bulb and contact are fine then try replacing it.
If all of those check out then it is a slight break somewhere. Prepare a lot of time and start tracing wires.
Old Oct 20, 2016 | 09:18 AM
ExplorerTominCO's Avatar
ExplorerTominCO
Which bulbs? The 4 on the outside of the vehicle or the 2 in the instrument cluster? Or are all 6 suspect?
My turn signals act the same way on my Expedition. I believe all my bulbs work. Mine seems to act up while it's raining and just after it's rained. Expeditions are known to have poor windshield seals and water can collect in one of the computers behind the fusebox.
