Need help with generator wiring
Old Oct 17, 2016 | 10:53 AM
wfo1955's Avatar
wfo1955
Could anyone lend a hand assisting me with a wiring diagram or narrative for the wiring of the voltage regulator, solenoid, generator and battery for a 1962 f250, 292? I really need your help as i have goofed something up. Thank you as always.
wfo1955
Old Oct 17, 2016 | 12:33 PM
1964FORDTUF's Avatar
1964FORDTUF
This is 1964 but should be same in regard to where the wires go - colors may be different. You may find the "junction block" is nothing more than a bolt and nut tying the eyes of the words together, and you probably won't find a 70 amp circuit breaker. If you do, by all means post a pic of it...What is it you think you goofed?
Old Oct 17, 2016 | 01:47 PM
wfo1955's Avatar
wfo1955
I replaced generator, prolly goofed it and voltage regulator. Thank you very much.
Old Oct 19, 2016 | 02:20 PM
wfo1955's Avatar
wfo1955
1964FORDTUF, thank you, that is EXACTLY what i was hoping for........perfect.
Old Oct 25, 2016 | 08:15 PM
1964FORDTUF
No problem. Thats what this forum is all about. Supporting fellow enthusiasts. Ive been helped many times.
Old Oct 25, 2016 | 09:34 PM
thrifty's Avatar
thrifty
Does that generator/regulator need to be polarized? If so, you need do that before it starts charging. Maybe someone will chime in. Good luck
Old Apr 11, 2023 | 08:47 AM
ajsunnyB's Avatar
ajsunnyB
I was wondering how your generator wiring worked out. I own a 1955 F-100 been working on it and realized the previous owner went from 6 volt to 12 volt and never told me what he did. Just changed the battery and nothing else. This caused a lot of issues and we are having fun now. Only item it did not effect was my head lights. Or I guess it did, because both were blown and I replaced them both thinking the high beam was out! But my high beam switch was totally blown apart. I found that yesterday. It shorted by a wire to ground that came off the headlite switch. Repaired the wire that came from the 6 volt light switch. I changed it to a 12 volt light switch. All the wires were wrapped in black electrical tape which ment that I had to remove all that tape to correct a bunch of shorted and burned wires. Reading your blog, I got my generator converted to 12 volt. But is my voltage regulator in A phase or .B phase.? I can’t find the answer for that. Kinda looks like my wiring now is maybe like the 1956 truck. But the semantic does not show the turn signals. Only a wire that comes from the brake lite switch. To the turn signals it’s a green wire that went directly to the rear brake lites on the six volt system. That wire was cut. So I had no brake lights. I’ve got a 1956 ford truck manual that came with my truck. It has a wire semantic. Today I want to get it enlarged and I will start tracing wire for wire. My voltage regulator is the big question on its phase.
Old Apr 11, 2023 | 10:04 AM
Crop Duster's Avatar
Crop Duster
You might want to try this forum 1948 - 1956 F1, F100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums (ford-trucks.com)
Everyone here has 61-66 trucks. Just click the yellow button at the top of the page that says New Thread and type away.
wfo1955
Oct 7, 2016 06:46 PM
blk5286
Electrical Systems/Wiring
Jun 5, 2011 10:12 AM
polarisman729
Jul 7, 2009 06:33 PM
53Trucker
Sep 20, 2005 10:24 AM
alec001
Oct 10, 2003 05:24 PM
