Wire (okay, vacuum line) burned in two, just noticed....
Old 10-16-2016, 08:15 PM
portsample's Avatar
portsample
portsample is offline
I just noticed a wire burned in half on the front side of the intercooler plenum. See picture below,
Here is the left side showing the green wire stub going into the wiring harness on the front side of the intercooler plenum,
and this is the right side showing the wire going into the air intake duct between the turbo and the air filter,
I don't think it's been in this condition very long. Thoughts on this?
Old 10-16-2016, 08:17 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,192 Likes on 818 Posts
Its not a wire its a vaccum line fix it or you will have dust go in thru that crack into the turbo.
Old 10-16-2016, 08:45 PM
portsample's Avatar
portsample
Ahhh, you are correct. I'm embarassed and relieved. The lines are really stiff (both the broken green and neighboring red), and the ends of the broken green are melted shut, so I don't think much if any dust has leaked in. Replacements have been ordered.
Old 10-17-2016, 10:20 AM
pirschwagon's Avatar
pirschwagon
pirschwagon is offline
Just get a Vacuum Tube with the same ID as the OD of the Green Tube and slide it over each end. Maybe four inches (two on either side of the break). If you do decide to replace it, use a rigid line, not rubber.
Old 10-17-2016, 12:07 PM
portsample's Avatar
portsample
I've already got the real deal on the way. Thanks.
bigtexan99
07-08-2017 07:24 AM
Dstosh
10-06-2016 07:03 PM
bf5113x
06-10-2016 02:38 PM
shoebox50
10-26-2004 08:23 AM
kf4zra
Aerostar
06-15-2004 06:04 PM
Quick Reply: Wire (okay, vacuum line) burned in two, just noticed....
