Maybe I haven't had enough coffee but why do the screens on post #2 & #3 look different? In one the tile slides up from the unselected ones and the other it slides down.
If I understand your point correctly, they do both. I just noticed it last night as I was playing around. Sure enough as soon as I found it.....my kid hopped in and we had to leave. I can tell you that if all color tiles are in the middle...ambient lighting is off. Not sure, but I'm thinking the lighting is on if the tile is either up or down. You can also adjust the tile to any position in between. I was doing this and trying to see if this dimmed the lighting. I only got a 10 second test in, but as far as I could see....it didn't do anything. That doesn't seem right though so I'll give it another try and let you guys know.
