Broken Air Compressor Fitting
Old Oct 31, 2016 | 04:28 PM
EDC8008's Avatar
EDC8008
Originally Posted by HRTKD
I drove to three different places today and the best they could come up with was a compression fitting for plumbing. No hose. I tried an O'reilly and two hardware stores.
After more research it looks like I can use the same hose and fittings used on pickup truck air bag systems. A kit of hose and fittings is about $39. I may call around to some 4x4 shops or maybe a diesel truck shop and see if they carry basic parts for air bag systems.
Go to your local NAPA not the typical auto parts stores or hardware stores as this is a DOT certified fitting and hose. There you'll be able to get fittings and hose, be sure and get extra as that one appeared short and added stress adding to the fitting failure.
Old Nov 1, 2016 | 08:41 AM
HRTKD's Avatar
HRTKD
I stopped by a NAPA that was close to work this morning. No joy. No hose, no fittings. I'm going to order a kit from Amazon that looks like it is a rebuild/install kit for air bags.
The kit includes a couple of 90 degree fittings. That should help reduce the stress on the hose so it doesn't have to make that bend.
Old Nov 1, 2016 | 11:40 AM
EDC8008's Avatar
EDC8008
Thats really strange as all the NAPA's I ever been in carry heavy truck parts and they use these for the air rides.
Old Nov 1, 2016 | 04:35 PM
HRTKD's Avatar
HRTKD
I hit a second NAPA on the way home. Still no joy. I ended up ordering a Firestone install kit that has tubing and fittings off of Amazon. Should be here by Friday.
Anybody need a couple feet of tubing? I'll have extra.
Old Nov 5, 2016 | 10:50 PM
HRTKD's Avatar
HRTKD
All done. The Firestone install kit has around 30' of tubing and a few fittings (two elbows, two valve stems and one T). Fortunately, there were two elbow fittings. I trashed the first one by breaking the quick connect part of it off with my wrench while tightening the fitting. With the elbow fitting instead of a straight fitting I think the hose ended up with a slightly better routing.
I considered mounting one of the valve stem fittings on the skirt of the trailer so I could pre-fill the air tank at home or at a gas station.
The compressor works, but it does seem a bit slow. It is a small compressor so I suspect that's normal. I forgot to drain the air after I tested it. I guess it will be a good test to see how well it holds air over a week.
I have no idea how much pressure is in the tank. There isn't a pressure gauge anywhere. The aforementioned valve stem fitting could have come in handy as a way to test the pressure.
Ford_Six
Jul 26, 2014 07:57 PM
rob8210
1997 - 2003 F150
Sep 3, 2011 05:00 PM
rpatrick
Garage & Workshop
13
Nov 13, 2007 05:58 PM
rmarquet
Garage & Workshop
Jun 24, 2007 08:07 PM
rednekf350
Garage & Workshop
Apr 2, 2006 02:48 PM
