Linex
Old Oct 20, 2016 | 08:59 PM
  #31
fordmantpw's Avatar
fordmantpw
Nice buck!
Old Oct 21, 2016 | 07:03 AM
  #32
toddstang's Avatar
toddstang
Originally Posted by Rasalas
Real nice ten. Guess around 22" spread" 195 lb body? Congrats on the deer.
Bingo!
Great call.
Thanks!
Old Oct 21, 2016 | 12:15 PM
  #33
omigosh's Avatar
omigosh
Had mind sprayed today. Turned out nice. The owner told me they don't like taking the bolts out on any of the aluminum beds so they sprayed over the bed bolts.
Old Oct 23, 2016 | 01:05 AM
  #34
DingusKhan's Avatar
DingusKhan
Wow I'm glad I found this forum. I thought Ford did much more for the bed liner. I will not be ordering that now.
I have a Jeep 4dr with a drawer system in it. It's made out of a dense foam board, not wood, then sprayed with LineX. TUFF AS HECK! Love it.
Now I just have to find a LineX dealer......
Old Oct 23, 2016 | 06:24 AM
  #35
Skipdaddie's Avatar
Skipdaddie
I've had a few factory liners and a few Line X. I didn't noticed a difference and both have been flawless, but I don't work my truck as hard as some of you. I went with the factory liner on my 2017 because it is only $425 on Z Plan and Line X is a hassle dropping my truck off for a day.
Old Oct 24, 2016 | 09:26 PM
  #36
kylant's Avatar
kylant
am i missing something in regards to the bolts. don't the steel bolts just pass through the aluminum bed and then thread into the steel frame?
what is the issue?
If the proper tool is used, i don't see why they would be difficult to remove and reinstall
Old Oct 24, 2016 | 09:36 PM
  #37
wb6anp's Avatar
wb6anp
In case the factory put anti-corrosion compound on them, if you remove them it should be reapplied. Cant have steel in contact with the Aluminum it will cause corrosion.
https://www.fleet.ford.com/truckbbas/non-html/Q-222.pdf
Old Oct 24, 2016 | 09:52 PM
  #38
Rasalas's Avatar
Rasalas
what is the issue?
The bed bolts are self threading which makes them self locking. The grains of the steel are bent in the direction of the turning force when they are installed and get fairly hot in the process. They have a tendency to seize the bolt making them very difficult to start back out. Once they start they turn no problem. When I have the Linex done I am having the installer anti seize the bolts just in case the bed ever needs to come off. I had to have a portion of the cab painted after a break in and the bolts were so seized the painter could not get them out. I later replaced the box and after breaking four of the torx bits finally cut the bolts off with a cutoff wheel. 8 bolts at $14.00 each was not an expense I enjoyed. The new bolts are external torx and should be easier to remove, especially on a new truck. I would have the torx socket for the installer, just in case he didn't find one. Torx Plus EP-24
Old Oct 25, 2016 | 09:16 AM
  #39
kylant's Avatar
kylant
now it makes sense, thanks guys.
does the factory just spray their liner over the bolts?
Old Oct 25, 2016 | 10:15 AM
  #40
Ozzie318's Avatar
Ozzie318
Great explanation! Also, Linex dealer mentioned there was a flat plate somewhere in-between and the first '17 they did, the plate slid loose and they had a hard time finding it and getting it back in place.
Old Oct 25, 2016 | 12:21 PM
  #41
Rasty1's Avatar
Rasty1
I'll bet because they did not have the proper torx socket.
Old Oct 25, 2016 | 03:24 PM
  #42
RubyRed350Platinum's Avatar
RubyRed350Platinum
My Line-X guys didn't have an issue. He said they came out a lot easier than what he thought they would have.
Old Oct 25, 2016 | 03:47 PM
  #43
EpicCowlick's Avatar
EpicCowlick
Boy that Companion looks great in there. I'm wondering how Line X is dealing with the overly large gaps in the bed. Are the trying to fill the gaps or are they still there after installation?
Old Oct 25, 2016 | 04:24 PM
  #44
RubyRed350Platinum
My gaps are still there. They of course aren't as large. However they still drain water just fine!!
Old Oct 25, 2016 | 05:58 PM
  #45
achec's Avatar
achec
is it better to have bolts sprayed vs. not sprayed or is it just preference.
Vilonia79
2004 - 2008 F150
15
Oct 15, 2014 06:38 PM
martin72
25
Aug 25, 2013 09:11 PM
Jdub289
2004 - 2008 F150
20
Jul 3, 2012 07:51 AM
CueMan's 78 F-150
Apr 30, 2011 07:22 PM
Bern_F150_4x4
Maryland Chapter
Mar 8, 2009 12:38 AM
