Fuel pump
Old Oct 12, 2016 | 11:17 PM
xaviar's Avatar
xaviar
Fuel pump
Hi all,
Well, I was cruising down the highway @70MPH and notice the fuel pressure gauge dropped down to 50 then back to 65. Kept watching the gauge and it would swing back and forth from 55 to 65.
Got off the highway. Nailed it at the light and watched the gauge drop to 53 and swing back to 65. Fuel pressure is not steady either. It swings back and forth from 52 to 65.
Thinking the pump is on its her last legs?
Any suggestions on a replacement pump or other options. Truck got 194K on her.
Thx, in advance.
Old Oct 13, 2016 | 12:25 AM
Yahiko's Avatar
Yahiko
Originally Posted by xaviar
Hi all,
Thx, in advance.
If you haven't already checked the primary filter I would do that first.
How full was the tank? If the level was down you might make a tool for checking
for aeration of the fuel.
Here is a tool I made to check pressure with. It has an orifice to simulate WTO
so that you don't have to do that.
Here is my tool. You can do static pressure and dynamic pressure.
When you open the valve to get the dynamic pressure you can watch the hose
to see if there is any bubbles in the line. That line can go right back to the tank
by just sticking the end into the filler or you can just a fuel can.
The orifice I had to order from the local Parker dealer and took about a week to
get it in. I got the idea from a post here in the forum some time ago.
Sean <BR>
6.0L Tech Folder
Old Oct 13, 2016 | 08:42 AM
xaviar's Avatar
xaviar
Fuel pump
Thanks for the reply Sean.
Didn't think about my filters. They both need changing. Haven't changed them since my trip to Canada in June or 7500 miles ago.
Like your setup there.
I'll do something similar.
Thanks again
Old Oct 13, 2016 | 09:26 AM
WatsonR's Avatar
WatsonR
It could also be the spring... Heard of the blue spring failing, ask Sparky
Old Oct 13, 2016 | 09:53 AM
xaviar's Avatar
xaviar
Will do. Might be a time to change it. I've put 100K on this truck since that mod was done.
Time for the fall maintenance before winter sets in.
Thanks.
Old Oct 13, 2016 | 10:55 AM
wedge542's Avatar
wedge542
If elec gauge sender may be on its way out, after cking filters ck blue spring for anything hung in area,then ck pump water drain for signs of rust or gum deposits,if there you need to clean the pump,look for any signs of seapege around any suction fittings from tank to pump. Have someone sit in truck after run awhile and turn key on while you under truck listening to sound while they cycle key,listen for changes in pumps sound from fast to slow,if changes alot pumps on its way out when it runs awhile and heats up.
Rory_Johnson
Mar 16, 2018 04:29 PM
M-S-G
28
Dec 30, 2014 04:12 PM
RideDiesel88
Sep 18, 2013 06:32 PM
ntoxdoc
1997 - 2003 F150
Jul 24, 2008 01:34 PM
jcstille
1997 - 2003 F150
Aug 15, 2007 10:15 AM
