HVAC issues
Old Oct 12, 2016 | 11:02 AM
gunner360's Avatar
gunner360
HVAC issues
I have a 2011 f150 xl with the basic climate system. I'm having a couple issues with my hvac system. Initially when I took over payments on this truck I was getting a little popping noise under the dash that would go away after a couple pops. I took the bezel off to look at the radio and how it was mounted for a separate issue when I put everything back together I started the truck and now that popping is constant (it is the blend motor actuator, I've already determine that and have a new one coming) the other issue I got is that now the ac will only blow through defrost no matter what button I push. When I start up it will blow out the defrost like the flap is in default then it will blow out of the dash for a few seconds and then go back to blowing out of the defrost. I still have speed control tho I don't have 1 ,which I didn't have before that, and I haven't tried temp yet but I'm assuming it still works. Do the newer trucks still use vacuum to control the flaps or is it all electronic? I've noticed when I look at the actuators they all have a plug end instead of a vacuum port. And would the defrost vent issue be a dash control issue or would it be the actuator for that one as well?
Old Oct 13, 2016 | 10:21 AM
WXboy's Avatar
WXboy
Sounds like you have a blend door motor failure. There are videos on YouTube on how to repair these at home. Search for "Ford Tech Makuloco" or something like that...I probably misspelled his name.
shortcakemedic
1997 - 2003 F150
Jul 30, 2017 04:30 PM
scottvp99
Aug 20, 2014 11:09 AM
librty02
2004 - 2008 F150
May 12, 2011 10:04 PM
MountaineerAWD
Feb 19, 2006 10:44 AM
RedRage
2004 - 2008 F150
Apr 5, 2005 01:33 PM
