Warranty Selection Thread
Old Oct 11, 2016 | 09:43 AM
Luckyc1423's Avatar
Luckyc1423
I am getting a f-350 diesel 4x4 short bed crew cab
What warranty should I get?
Premium, extraCare, BaseCare, PowertrainCare
Just to compare prices, from flood ford
7 year 150,000 miles no deductible
1) Premium: $4,555
2) Extra: $3,235
3) Base: $2,660
4) PowerTrain: $2,120
such a huge price difference between all plans, I'm not sure what to get.
Old Oct 11, 2016 | 10:19 AM
AK_SuperDuty's Avatar
AK_SuperDuty
1) Premium: $4,555
2) Extra: $3,235
3) Base: $2,660
I'll be going with the 8 year/125k Premium when my truck gets here. The premium is the only way to if you have lots of gizmos and gadgets. What trim level are you going with?
Old Oct 11, 2016 | 10:21 AM
Luckyc1423's Avatar
Luckyc1423
Platinum
But the only difference between the premium and the stepbelow is Audio, Safety, and something else.
For $1,000 difference is it worth it?
Old Oct 11, 2016 | 10:36 AM
wb6anp's Avatar
wb6anp
Price the ESPthrough Flood ford and see if it less and i always go with premium care.
Old Oct 11, 2016 | 03:55 PM
Rasty1's Avatar
Rasty1
^^^ Will be a good point to negoitate with your dealer
Old Oct 11, 2016 | 04:30 PM
Luckyc1423's Avatar
Luckyc1423
The prices I mentioned are flood ford prices
Old Oct 11, 2016 | 05:42 PM
EpicCowlick's Avatar
EpicCowlick
Here's the prices if you buy at delivery:
And here's the price over one year of ownership and 20,000 miles:
It's $100 more to wait to buy. That's not much cost to give yourself some time to make up your mind.
Old Oct 11, 2016 | 08:02 PM
srkr's Avatar
srkr
I bought the premium care 5yr/125,000 100.00 deductible from dealership for 3180.00
I got taken to the cleaners.
Old Oct 11, 2016 | 08:18 PM
DL222's Avatar
DL222
Ouch I wonder if you can cancel and get your money back?
Old Oct 11, 2016 | 08:28 PM
mccmann's Avatar
mccmann
I was told you could cancel, and also get pro rated money back if you sell it, or it can transfer to next owner.
I went with 6 year 150000 miles premium at dealer 3220.
Just picked up my F350 XLT Crew Cab Caribou yesterday!
Peace of mind. Won't know for years if it was right decision?
17 Oaks's Avatar
17 Oaks
I entered all 3 plans into a spread sheet and did a comparo and the winner was:
ExtraCARE. Bang for your buck its the best plan and its what I purchased from Flood....
You too can spend about 6 hrs sorting it all out, just click on MS Excel and enter ALL the data points and there are a lot:
Here is a start for ya:
113 data points in the Premo plan:
Engine
All internal lubricated parts
Cylinder block
Cylinder heads
Diesel injectors and lines
Diesel injector pump
Diesel lift pump
Engine mounts
Flywheel
Flywheel ring gear
Gas fuel injectors and lines
Harmonic balancer and bolt
Manifold, exhaust
Manifold, intake
Oil pan
Oil pump
Radiator and radiator fan
Radiator fan clutch or motor
Seals and gaskets
Thermostat
Thermostat housing
Timing chain cover
Timing chain, gears or belt
Turbocharger/Supercharger unit, factory-installed
Valve covers
Water pump
Transmission
All internal parts
Governor assembly
Seals and gaskets
Torque converter
Transfer case, including internal parts
Transmission case
Transmission module, external
Transmission mounts
Vacuum module
Front-Wheel Drive
Axle shafts
Bearings, front-wheel
Bearings, rear-wheel
Constant velocity and universal joints
Final-drive housing and all internal parts
Hubs, automatic front-locking (four-wheel drive)
Locking rings (four-wheel drive)
Seals and gaskets
Rear-Wheel Drive
Axle shafts
Drive-axle housing and all internal parts
Drive shaft
Retainers
Seals and gaskets
Universal and constant velocity joints
Air Conditioning & Heating*
A/C clutch
A/C accumulator
A/C clutch bearings
A/C compressor
A/C compressor head
A/C compressor seals
A/C compressor/clutch switch
Automatic temperature control
Condenser
Evaporator
Field coil
Heater blower motor
Heater core assembly
Pulley
Brakes
Anti-lock brake module and sensor
Backing plates
Brake booster, power
Calipers
Combination valve
Lines and fittings
Master cylinder
Parking brake linkage and cables
Retainers and clips
Self-adjusters
Shaft brake pedal
Springs
Wheel cylinders
Electrical
Alternator
Backglass, heated (Electrical only - not glass damage or breakage)
Distributor assembly
Distributor cap and rotor
Distributor housing and shaft
Fuel pump
Ignition module, electronic
Ignition switch
Radiator fan relay
Starter motor
Starter motor solenoid
Switches, manually operated Electrical
Voltage regulator
Wiper motors
Wiring harnesses (excluding spark plug wires)
Front Suspension
Ball joints, upper and lower
Control arms, upper and lower
Control arm shafts and bushings
King pins and bushings
Linkage and bushings
Spindle and spindle supports
Stabilizer bar
MacPherson struts (front and rear)
Tie rods
Steering
Column lock (tilt wheel)
Cooler and lines
Control valve
Cylinder
Idler arm
Linkages and couplings
Power Steering pump
Pulley assembly, power Steering pump
Seals and gaskets
Steering gear housing, manual and power (includes all internal parts)
High-Tech
Air suspension, electronic (selected components)
Compass and thermometer readout displays
Instrument Cluster,
Electronic (Excluding
Dash Pad, Clock, Audio
and Visual Equipment)
Keyless entry system (excluding door handles)
Power antenna
Power door locks and retainer clips (excluding door handles)
Power seat motors
Power window motors/regulators
SecuriCode™ Keyless Entry
Speed Control
Old Dec 27, 2016 | 03:18 PM
347Flatty's Avatar
347Flatty
Isn't the power train already covered for 100k? So really what your buying is coverage for everything else from 36k when the warranty ends to whatever you choose correct? Maybe I'm missing something with the extra esp coverage?
Old Dec 27, 2016 | 04:48 PM
Tomc750's Avatar
Tomc750
Air Suspension? What air suspension???
Old Dec 28, 2016 | 10:49 AM
17 Oaks's Avatar
17 Oaks
Miles and time beyond the coverage points...
Dunno, but its on the plan????
Old Dec 28, 2016 | 11:22 AM
oklarado's Avatar
oklarado
Its for the new Lincoln Superduty blackwood edition. Due to the increased demand for the high end models Ford thought it would sell. Release date is April 1st.
