2006 6.0 fan shroud removal question
Wish my dealer read this thread before changing the front main seal ony truck...they decided it was reasonable to cut the shroud in two, then screw it back together...
Got a Youtube for you that Ron (aka : DieselTechRon) did on how to remove the shroud.
WITHOUT CUTTING,
Sean <BR>
6.0L Tech Folder
WITHOUT CUTTING,
Sean <BR>
6.0L Tech Folder
Yes, take out the radiator brackets and battery cable hold downs. Two screws hold the front fan shroud in, take them out. The bottom of the front shroud has tabs that fit in the bottom of the radiator mount.
The front shroud just pulls up out of the engine compartment. It isn't real easy, but it'll come out.
I took it apart the first time, learned from that.
dieseltechron has this on youtube (rip), he was the greatest.
bolt locations were are they
Bolt locations
where are the fan shroud bolt locations
