8.8 swap
Old Oct 9, 2016 | 09:31 PM
Rollingscrapmetal's Avatar
Rollingscrapmetal
8.8 swap
Anybody know what it's going to take to put a 9 inch out of one of the trucks into an 80s truck
Old Oct 9, 2016 | 11:46 PM
greentruck72's Avatar
greentruck72
if the dimensions are the same, it'd be as simple as unbolting the one axle and bolting it in the place of the other, if not cut the mounts off and re weld them were you need them.
Old Oct 10, 2016 | 09:04 AM
Rollingscrapmetal
I'm hoping to just unbolt the other one and bolt this one in
My 8.8 has an ungodly number of miles on it and the 9 could be rebuilt and swapped out hopefully fairly quickly
they already have similar gear ratios 3.55-3.50
Old Oct 10, 2016 | 09:55 PM
Dirt racer's Avatar
Dirt racer
I was wondering if the driveshaft length would be the same. Was thinking about doing this swap sometime in the future
Old Oct 15, 2016 | 07:16 PM
Rollingscrapmetal
I didn't think about the driveshaft but it should need lengthened if anything I don't think it'll matter
New question do they use the same brakes it's out of a 74 if it matters I bought new pads and drums for the 8.8 before I got the 9 and wanted to swap them
Old Oct 16, 2016 | 01:41 PM
Rollingscrapmetal
So after googling for a while I learned
late 80s ford uses 12365026 centric part
early 70s ford uses 12365005 centric part
They're about the same size around
70s is ~2-1/4 across
80s is ~2-1/2 across
With any luck I only need to keep my drum backings
Aquaman78F100
1983 - 2012 Ranger & B-Series
Aug 12, 2008 10:48 PM
Brian460
Apr 13, 2008 12:22 AM
Bowtie's gone
Feb 11, 2004 12:10 PM
twxsby
Apr 13, 2003 11:26 PM
FordPerf300
Aug 7, 2002 05:21 PM
