Merc 4" crank
Old Oct 9, 2016 | 09:06 PM
3twinridges's Avatar
3twinridges
Merc 4" crank
Folks, I happened up on a Merc 4" crank this weekend. Cleanout holes are 5/8, marked f1601, largest counter weight is 6" across. Any other characteristics I should check to make sure? It's not marked 1cm.
Seller says its 10 under already and should clean up at 20 or 30 under. Sounds like it's worn out to me, thoughts on that?
JB
Old Oct 9, 2016 | 09:22 PM
jmadsen's Avatar
jmadsen
If the things not cracked anywhere 30 under bearings should still be available. Even if it was 40 under could still be ground as a stroker.
Old Oct 9, 2016 | 10:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Are the sludge trap plugs threaded? That's another clue. Measuring the throw is the best guarantee.
Old Oct 10, 2016 | 12:57 AM
Overkill-F1's Avatar
Overkill-F1
Does it have the Mercury Dimple?
...Terry
Old Oct 10, 2016 | 02:33 PM
3twinridges
Thanks guys, I am talking to him tonight. Technically, would a Merc crank fit into year 8ba block from 49-53? Also would the crank to cam alignment marks be the same?
Old Oct 10, 2016 | 02:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The only other thing that needs to change are the pistons
Old Oct 10, 2016 | 03:11 PM
3twinridges
Thanks Ross, fingers crossed on a non cracked block, I am going to bore it 100 over and slide a merc crank in it and keep the stock look.
JB
PurelyFord
32
Jan 25, 2019 12:00 PM
cts1954
Aug 3, 2007 07:14 PM
51dueller
Flathead V8 & Flathead 6
Apr 11, 2004 07:37 PM
mimsand
Sep 13, 2001 10:32 AM
Ratsmoker
Jul 18, 2001 03:43 PM
