Flathead Crankshaft
Old Aug 2, 2007 | 09:07 PM
cts1954's Avatar
cts1954
Flathead Crankshaft
What is the best way to measure a crankshaft that is out of its bearings to verify if it is a 3 3/4 inch or 4 inch stroke crankshaft.
wgc
Thanks
Old Aug 2, 2007 | 09:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Do you mean to verify if a seller is telling the truth about a crank for sale? Or on your existing engine? If on your existing engine, the piston crown-to-pin height will tell you.
At any rate, I think I'd put the crank with two throws horizontal. Then get two long straightedges, and put one on each of the two horizontal throws, with the straightedges on the centerline of each throw, parallel to the crank. Then measure between the straightedges and divide by two. It depends how accurately you can eyeball the centerlines. A Merc crank would have 8" between the striaghtedges, a Ford would be 7-1/2".
There are forging marks that allegedly identify Merc cranks, on the front counterweight. I can't remember what it is, 4TL8Ford probably knows, or MTFlat....
Old Aug 2, 2007 | 10:00 PM
mtflat's Avatar
mtflat
Some merc cranks have a square-ish dimple on the front counterweight.
Also check the cleanout plugs. Typically Ford 3 3/4 used 3/8" plugs while the merc 4 used 5/8" plugs.....however Canadian merc cranks have been reported with small cleanout plugs.
The only sure way it as Ross suggested - measure the throw.
Old Aug 2, 2007 | 10:15 PM
cts1954's Avatar
cts1954
Thanks, it is a crank I have picked up with an engine a while ago (block and pistons are gone), it was a 53 truck engine. Are all Ford 53's 239 engines or were some 255's. It does not have the dimple on the counter balance and I am almost sure it is a 239 crank untill someone told me that Ford engines in 53 were 255 cu.
wgc
Old Aug 2, 2007 | 11:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
No, they were 239's in '53 F-100's; I don't think the bigger trucks had anything different.
Old Aug 3, 2007 | 07:22 AM
4tl8ford's Avatar
4tl8ford
After almost 60 years of the 8 series Flathead engines being used repaired, modified etc the only sure way to tell what any individual part is would be to find a part number or measure.
NOTE: Part numbers weren't stamped on anything important.
I just pulled apart a Flatmotor in a 51 Panel, Left Side Head 8BA (Car Type), Right Side Head 8CM (Merc), Block Red Paint (Truck, Flaking badly). Conclusion, after measuring, Typical late Ford Flathead.
Old Aug 3, 2007 | 08:15 AM
cts1954's Avatar
cts1954
Thanks, I didn't think the 255 was used in the Fords from the factory, but i thought I had beter check with the experts before I gave away a 4" crank.
wgc
Old Aug 3, 2007 | 10:09 AM
4tl8ford's Avatar
4tl8ford
wgc
Well, Thats Rude! We give the best we have and you want experts? Go figure.
Old Aug 3, 2007 | 11:00 AM
cts1954's Avatar
cts1954
Sorry for calling you guys experts, what would be worse is to get rid of a 4" crank for $50.00, Canadian dollars as well.
wgc
Old Aug 3, 2007 | 03:31 PM
4tl8ford's Avatar
4tl8ford
wgc
Now that would create a mamoth negative pressure area.
(Technical Talk)
Old Aug 3, 2007 | 07:14 PM
mtflat's Avatar
mtflat
Last I checked US and CAN dollars are on par
Don't discourage him Dick, I like it when I'm thot of as an expert!! It doesn't happen very often - just let me bask in the glow
.......you can fool all of the people some of the time and some of the people all of the time, but you can't fool mom.... "Capt Penny"
irsmun
Modular V8 (4.6L, 5.4L)
Aug 2, 2015 11:10 AM
ScallyWaggler
May 16, 2015 02:03 AM
chosen69
Jan 29, 2015 08:05 PM
TMI
Apr 10, 2014 09:19 PM
Gettysburg150
Mar 11, 2014 02:59 PM
