wheel bolt pattern
Old Oct 9, 2016 | 02:23 PM
FOMOCOJOHN's Avatar
FOMOCOJOHN
wheel bolt pattern
I am wanting new wheels BECAUSE I am adding Heidts or a TCI IFS kit. The current bolt pattern on my wheels is 5 x 5.5, but the kits will only accommodate a 5 x 4.5 (Ford) pattern. I can buy new wheels cheaper that the adapter kits sold as an add on, but that takes care of the front only.
My question: do they sell spacers or adapters for my rear wheels, or am I going to need to replace the hubs itself? And then, worry about the brakes fitting correctly, etc.
Other option would to be to find a wheel sold w/ both bolt patterns.
I'm asking you guys w/ lots more experience in these matters what they might do.
Old Oct 9, 2016 | 03:16 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Have your axles re-drilled for the bolt pattern you wish. I had a set of truck axles re-drilled to the 5x4.5 bc so the wheels would fit any corner.
Old Oct 9, 2016 | 03:18 PM
pbsdaddy's Avatar
pbsdaddy
There are a couple companies that make adaptors. I have never used them as I was always concerned about the amount of metal left, once all those holes were drilled. Since they are not the sole support for anything, my concerns are probably unjustified.
SET Group USA - Supreme Engineering Technologies ? Set Group USA
Old Oct 9, 2016 | 04:22 PM
FOMOCOJOHN's Avatar
FOMOCOJOHN
I appreciate your suggestions.
Old Oct 9, 2016 | 06:39 PM
56panelford's Avatar
56panelford
You could also switch out the rear diff with one out of an Explorer and have the 4.5 inch bolt pattern and have rear disc brakes too, just another option to consider..
Old Oct 10, 2016 | 06:45 AM
GreatNorthWoods's Avatar
GreatNorthWoods
The cheap way out...you could run the 5 x 4.5 front and 5 x 5.5 rear and carry an adapter from 5.5 to 4.5. That way only one spare would be needed. I did that for years on an old Ford I had years ago.
Old Oct 10, 2016 | 09:32 AM
Justboy's Avatar
Justboy
Good idea
Old Oct 10, 2016 | 09:44 AM
FOMOCOJOHN's Avatar
FOMOCOJOHN
I am liking this forum, great suggestions!
Old Oct 11, 2016 | 12:48 PM
petemcl's Avatar
petemcl
The other alternative is to put a small portable air pump under the seat. Think about the flats that you have had. Most only that I have had have been slow leaks from a nail or something in the tire. An air pump most of the time will pump your tire up enough to get you someplace where a permanent fix can be made. That is an easier and safer alternative than changing a tire on the side of the road under less than ideal conditions.
Bat4x4
Aug 20, 2016 12:00 AM
rock7174
Aug 25, 2014 08:06 PM
phatkat
Jun 16, 2010 10:23 PM
diesel77
Feb 22, 2010 12:23 PM
ragingbull
Aug 23, 2002 01:55 PM
