1951 F2 engine swap
1951 F2 engine swap
I just received the bad news... 7 cracks in my flathead... the machine shop says they are all repairable, but I'm thinking the cost to repair them plus everything else kind of puts it out of my budget.
So...
I have a good running, stoutly built 302 with around 1000 miles on it, and an AOD with around 50 miles on it that I pulled out of my '64 Fairlane back in the spring...
I'm considering swapping in the 302/AOD, hopefully without making any permanent changes to the frame or body, so that I can always return the truck to its stock configuration in the future if I decide that I want to.
Is this a realistic goal?
Also, is there a recommended bolt in engine mount/crossmember that is recommended?
I am planning to use a stock F1 front axle (thanks, Firstrider) with a disc brake conversion and a 9 inch rear ffom a '66 f100.
Any other advise?
Thanks -Bear
So...
Any other advise?
Thanks -Bear
So...
Any other advise?
Thanks -Bear
So...
Any other advise?
Thanks -Bear
Silver... here are the pics....
kens65fb
10-28-2016 07:36 AM
61UniB100
01-30-2007 10:34 AM
badtomatoes
03-10-2006 12:02 PM
Greywolf
04-24-2002 06:19 PM
