2016 leveling kit, what one
Old Oct 8, 2016 | 06:28 PM
Daveyf15096's Avatar
Daveyf15096
What is the best leveling kit for the 150. Is there any issues with installing the kit. Does it hurt the truck in any way. Does it affect warranty. I would assume a alignment would be needed too after the install. Any one have info about this and if there is any problems with installing these type kits. It looks like the 2 1/2 spacer is whats used. do they have the spacers in different incraments. About a month ago I traded a 13 350 diesel for a 150 xlt eco.
Thanks
Dave
Old Oct 8, 2016 | 07:58 PM
TJReams's Avatar
TJReams
I saw a post somewhere about the dealer wouldn't warranty his ball joints or tie rod ends after he had a 2.5 lift installed. I haven't heard or seen a post with problems on the 2" lift.
Old Oct 9, 2016 | 09:22 AM
cdmm151's Avatar
cdmm151
I have used rough country and autospring. Both are good, just different material. If you have a Crew Cab definitely need 2 1/2. Makes the truck look level. Depends on the dealer as for warranty. Some are pure butts about after market add on's. I always remind them about trucks they jack up prior to selling them. Are they going to warranty that. You bet they will. You will need to realign. Best thing you can do to a truck.
Old Oct 10, 2016 | 09:13 PM
Daveyf15096
Thanks .It is a 16 crew cab ecoboost. A friend has a chevy and he installed a leveling kit and his steering was making a clicking noise. He researched it and was a common thing. he removed the kit and it was normal again. I don't want any issues like that.
Old Oct 11, 2016 | 07:03 AM
Haw River's Avatar
Haw River
Dumb question but why are they not level to begin with? Is it an aerodynamic thing to improve MPG's?
Old Oct 11, 2016 | 07:48 AM
cdmm151's Avatar
cdmm151
Follow the directions and should not have problem. Only issue came up in 2011 when the EPAS was new. Instructions did not say to disconnect battery. I was one of the first to find this out and Rough Country paid to have it fixed. You can say I had them change the instructions.
Old Oct 11, 2016 | 12:45 PM
Leadsled124's Avatar
Leadsled124
Those leveling spacers work but you always get that clunk. Id just get a set of those Bilstien 5100 Leveling shocks. Their cheap and ride really well for the price. If there not out for the '16s yet i remember seeing another company that started making the same thing. Cant remember brand. Basically has 3-4 slots for the C-Clip to sit depending on desired ride height
Old Oct 11, 2016 | 12:47 PM
Leadsled124
I heard about that too when i had my '11 3.5. I ignored it and never had an issue. I did remember though hearing about the electric steering having issues though when you turn the wheel while installing with truck off. Weird i don't know why
Old Oct 11, 2016 | 06:07 PM
mts6175's Avatar
mts6175
This. I had a bad experience with a Ready Lift Spacer Kit on my Tundra, it's ultimately what made me get rid of it and into a F250. I would go the 5100 route or look at the Fox 2.0's as well, although I'm not 100% sure if they make the adjustable height coil overs for the F150. I would also recommend the ProComp Prorunner adjustable height ones, I pulled the spacer kit off my Tundra and swapped it for those, it was much, much better. But they are pretty much the same as the 5100's.
Old Oct 11, 2016 | 06:56 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The rear end sits higher for payload. Add a load in the bed and the truck levels out.
If the truck was already level and a load is added it will squat down and look ridiculous.
Josh
Old Oct 11, 2016 | 10:50 PM
djjoshuad's Avatar
djjoshuad
Josh
QFT
not only will it look ridiculous, it will raise the headlight beams directly into the eyes of everyone in oncoming traffic. Every time I see a truck with a leveling kit I wonder if that guy ever actually hauls or tows anything
Old Oct 13, 2016 | 07:51 PM
Haw River's Avatar
Haw River
Dang! that was a dumb question now that you explain it, but does that mean guys that level their trucks are not normally hauling much weight ever? And how much weight would it take to tip the headlights up......not a jon boat, battery and outboard or would that be enough to do it? Would 700-800 pounds be enough?
Old Oct 13, 2016 | 11:55 PM
djjoshuad's Avatar
djjoshuad
on a trailer? nah you'll be fine. in the 5.5' bed of a supercrew? yeah that's probably enough to make it rake backwards a bit. get anywhere near the payload limit and it will look like your truck has worms.
Old Oct 14, 2016 | 09:38 AM
Haw River's Avatar
Haw River
I was thinking all that gear thrown in the 6.5 bed
Old Oct 14, 2016 | 09:50 AM
djjoshuad's Avatar
djjoshuad
it will squat some, but it won't be a full squat. you might not blind oncoming drivers with that light of a load, but it will very likely have a noticeable rake to the rear. a rear add-a-leaf (about $300 including labor) will solve that problem. the leveling kit still won't get you the offroad capability of a real suspension lift, though. if that's what you're after.
