Accessory Wiring
Old Oct 8, 2016 | 04:07 PM
DiamondDave1984's Avatar
DiamondDave1984
Accessory Wiring
Hello Everyone, just bought a 2017 F250 Lariat CC with 6.7. I tried to wire up my radar detector to a switched blunt wire or fuse without success. I cannot get any power from the cluster of blunt cut wires at the fuse box. I actually had some hill descent and advantrac warnings while testing the wires with a tester and now have an engine symbol on the display. I did not have this problem with my 2008, 2010 or 2013 Super Dutys. Any suggestions will be appreciated. Thanks, David
Old Oct 8, 2016 | 06:08 PM
Canwan's Avatar
Canwan
Do you have upfitter switches?
Old Oct 8, 2016 | 06:20 PM
DiamondDave1984
Hey Canwan, No upfitter switches..
Old Oct 8, 2016 | 06:59 PM
69cj's Avatar
69cj
Those are probably just the pass thru wires from inside to the engine compartment.
Old Oct 8, 2016 | 07:26 PM
msdt-99517's Avatar
msdt-99517
Just had mine done on the 15 amp fuse in the fuse box. It's the one towards the bottom.
Old Oct 8, 2016 | 07:42 PM
DiamondDave1984
Is that 15 amp fuse switched?
Old Oct 8, 2016 | 07:43 PM
69cj's Avatar
69cj
They are just pass thru's if there are 4 of them.
Old Oct 8, 2016 | 07:46 PM
msdt-99517's Avatar
msdt-99517
Yes, he tapped it in on the fuse facing the firewall
Old Oct 8, 2016 | 07:58 PM
DiamondDave1984
There are approx 20 wires at the fuse box. They have lables with color codes that mean nothing to me so I used one with "VS......", thinking vehicle switch, that would not work. My 2013 had the same looking bundle and I just connected hot to the Passport power cord and kt was still working when i traded. I will try the 15 amp fuse location. Thanks
Old Oct 8, 2016 | 07:59 PM
DiamondDave1984
Can you post a picture????
Old Oct 8, 2016 | 08:11 PM
msdt-99517's Avatar
msdt-99517
He tapped the fuse not the wire, he wrapped on the side that faces the firewall on the fuse. He is a master installer in texas. He used that side so if anything happens it will blow the fuse. He has done 100k builds for Sema and many of my vehicles so he knows what he is doing.
Old Oct 8, 2016 | 08:12 PM
msdt-99517's Avatar
msdt-99517
All put back together
No sorry, it's all put back together
Old Oct 8, 2016 | 08:45 PM
Canwan's Avatar
Canwan
Somewhere I had seen the upfitter guide. That would have the information you need. I'll see if I can find it again.
Old Oct 8, 2016 | 11:05 PM
Azuretruck's Avatar
Azuretruck
Where in Texas is he? I may require his services. I'm in the Dallas area.
Old Oct 9, 2016 | 02:47 AM
msdt-99517's Avatar
msdt-99517
Alvin.........
R23DRVR
Sep 8, 2012 12:45 PM
casey meece77
Sep 28, 2011 08:29 PM
salesman112
Electrical Systems/Wiring
Jan 7, 2008 01:15 PM
KyleL
Nov 29, 2006 05:34 PM
mike9497
Oct 26, 2006 04:53 PM
