1995 F150 4.9 Sputter / miss especially when warm
SOOOO, working on a 1995 F150 2WD 4.9/automatic
It came to me missing horribly under throttle/load, I installed an EGR restrictor plate with two small 1/8" holes. Check engine light cured and engine runs much better.
BUT
On cold startup it will fire and die immediately then restarts without issue... this in itself isn't my concern, just mentioning it for the sake of transparency.
The issue: the truck will go down the road Ok (not great) when cold but once it warms up it misses if I give it 1/4 throttle or more, if I keep my foot to the floor it will start to miss more. It will gain speed but sputters its way up in RPM and sounds like it's losing fuel or spark.
*ALL new tune up parts were on it when I got it, cap, rotor, plugs, wires etc.
*No codes No CEL
*fuel pressure gauge shows a rock steady 35 PSI idling, WOT etc.
*Have not detected any vaccum leaks
*unplugged the Fuel pressure regulator vacuum line and it didn't really change anything.
*Plugs are nice and clean, look like they are burning at the right temp.
Any ideas from you gents?
BUT
*No codes No CEL
Seems logical, I've had 302's run great with 30-40psi. Seems odd to me that these would require more (I know the book says so) if there's a Simple nozzle difference it could make it spray lazy with lower pressure I suppose. I just figure I'd have seen a wet plug in at least one cylinder if that was the case. This morning I'm going to pull the filter and see if she's plugged up.. Then on to the pump
Correct, In my experience you would experience a drop at WOT if the pump was bad but I'm not finding a lot of info on the 4.9 and its apparent need to really high fuel pressure. So I'm sort of taking educated guesses at this point.
I'm suspecting the pump now that I've studied the fuel pressure more extensively. Once completely warmed up It does actually dip a few psi when you blip the throttle (under hood turning the throttle body). And if I hold the RPMs at 1500-1800 the psi will dip about 5 psi and then it will level out again.. But it's NOT increasing from 35 psi under any circumstances or rpm.
Fuel pressure should be 45-60 psi for the 300. If it's lower it won't run properly. You say if it's hot it's even worse? Sounds like a fuel pump to me. I just went through the same issues, replaced both tanks pumps and now my 95 300 runs great. I posted on the topic myself.
https://www.ford-trucks.com/forums/1...imination.html
WHY???
So I installed the new pump, made sure my butt connections were nice and tight. Plugged it all in and the new pump is showing zero psi on the fuel rail... Tried cranking and cranking to no avail. Swapped the relay with a known good one and no change. Shows I'm getting 5 Volts key on engine off at the fuel pump pigtail. I would think it should show more than that?? But either way the old pump made 35 psi with the same wiring... Inertia switch is fine as well. Any ideas or am I missing something?
