Sponsored by: Real Truck
Smaller spare tire abs issues?
Old Oct 7, 2016 | 10:05 AM
Norma stitz's Avatar
Norma stitz
Has anyone tried putting a stock spare on while running 35's on the truck? Does it spaz out completely or is it okay?
Old Oct 7, 2016 | 12:12 PM
Chuck's First Ford's Avatar
Chuck's First Ford
I'm sure it will ... different diameter, different rpm speed.
ABS expects all 4 wheels to be turning at the same rpm on good roads... and the smaller will be turning faster..
Old Oct 7, 2016 | 01:02 PM
Wingit929's Avatar
Wingit929
Don't know why you would.
Honestly it depends on what year you got. Newer vehicles have a sensor at all four corners. Older models did not.
Old Oct 7, 2016 | 02:29 PM
Norma stitz
Interesting. Not sure how abs would work without a speed sensor on all 4. Only reason I ask is some vehicles are known to have more issue than others so just wondering. Recently got 35's but still have stock spare and would prefer to keep it if it's useable.
Old Oct 7, 2016 | 05:18 PM
Layson's Avatar
Layson
For a short time it will be fine. Your ABS really doesn't give a crap about it.
I have ran a stock spare tire with 40's below. It was on the front and for a short time. It will be fine.
Your speedometer is mainly dependent on the rear speed sensor in your rear axle.
Run the tire on the front of the truck.
Old Oct 7, 2016 | 05:31 PM
Norma stitz
Thanks. I know the sprinter forum jumps everyone's *** if they propose a stock spare and even slightly oversize tires which I find funny since not a one of them have ever tried it so I did and it was no problem at all. Sometimes things that seem impossible on paper are in fact non issue.
vrinner
Oct 21, 2016 10:55 PM
bluedevil3758
1983 - 2012 Ranger & B-Series
Apr 22, 2009 11:37 AM
7700Rob
1997 - 2003 F150
Nov 13, 2007 06:52 AM
gkruk
2004 - 2008 F150
Apr 16, 2007 01:30 PM
mwellner
1978 - 1996 Big Bronco
Nov 4, 2003 12:14 AM
