Weird Tail light issue...
Old Oct 5, 2016 | 03:37 PM
grayson20's Avatar
grayson20
Alright here's my phenomenon. I have a 2001 f250 7.3 ext cab long bed 4x4 with a flat bed on it. I actually have 2 issues. I hooked up to my father n laws gooseneck trailer to pull a tractor. I noticed right after I unhooked that when I have my running lights on and step on the brake pedal my drivers side brake light comes on and my passenger side running light goes off and no light at all comes on on that side. Any one heard of this? Any way to trouble shoot this? Thanks!
Old Oct 5, 2016 | 08:38 PM
Walleye Hunter's Avatar
Walleye Hunter
Do they share a ground? If more than one light is on a ground and the ground goes bad things like this will happen.
Old Oct 5, 2016 | 08:55 PM
cangim's Avatar
cangim
With your running lights off, do you have brake light on passenger?
Old Oct 6, 2016 | 08:19 AM
grayson20's Avatar
grayson20
On my flat bed I have two lights either side. one that is a reverse light only and is a clear lens and one that is a red lens and performs my turn signal, running and brake light function. they are the generic oval non led lights you can get about anywhere. they both have a ground coming out of them and I have them both grounded on the same bolt in the back of my flatbed. I have also noticed that on the same side I am having the issue with than when I turn that side signal on both the front and back signal flashes really fast.
Old Oct 6, 2016 | 08:23 AM
grayson20's Avatar
grayson20
Walleye, do you think I would be better off grounding each light separately? cangim with out my running lights on I still do not have a brake light on that side. I assumed those little oval lights were all one bulb. they are sealed anyway and I cant get inside of them to see. they around only a few months old.
Old Oct 6, 2016 | 08:25 AM
grayson20's Avatar
grayson20
When I took my box bed off to put my hay bed on it was a pretty simple deal (or so I thought) I unplugged my trailer wiring harness and then mounted it on my flat bed and plugged it back in. and then when right off my original harness to these lights. everything worked great.
Old Oct 6, 2016 | 09:19 AM
Walleye Hunter
I never had to do that, just a good cleaning of the ground wire and smearing up with some sort of grease to prevent future corrosion.
Old Oct 6, 2016 | 08:13 PM
cangim's Avatar
cangim
So should be three wire plug then. Sounds like the bulb is out. You can ohm the brake wire see if there is any continuity. Then it will decide lamp housing vs wiring. Fast flash is similar to switching to leds, low current draw, burnt tail light would result in a lower draw.
Old Oct 7, 2016 | 01:29 AM
79jasper's Avatar
79jasper
It is just one bulb inside.
I agree with the rest, sounds like a ground problem.
Old Oct 7, 2016 | 07:22 AM
pirschwagon's Avatar
pirschwagon
Attached are the Wiring Diagrams for your vehicle (Rear Lighting). Begin by identifying Connectors. Then determine if the Circuits are Open/Closed. Check Ground Circuits for continuity to a KNOWN good ground such as a Frame Bolt.
Electrical problems often take a good amount of time to troubleshoot. But, repairs are usually a few minute fix.
Good Luck!
File Type: pdf
Old Oct 7, 2016 | 09:21 AM
grayson20's Avatar
grayson20
awesome thanks for the help guys, I will re-rout grounds and start over. I basically had grounds ruled out but I will revisit that. I assumed the bulb was still good because it would still light up for the turn signal and the running light. It blows my mind why if both running lights are on and I step on the brake the running light would go off and nothing would be on on that side??? I guess grounds do funny things......here is the funny thing. When I hook up to my gooseneck trailer my signal stops flashing fast and flashes normal? that because my trailer is grounded well? My brake light issue transfer back and does the same thing on my trailer though....
Old Oct 8, 2016 | 12:03 AM
DaveP.'s Avatar
DaveP.
The bulb has two filaments. One bright (brake / turn), one dim (tail). They each have an input wire, and share a common ground. 3 wires.
The bright filament draws a lot more current than the dim filament. The bright filament can easily conduct the current for the dim filament through itself into it's power wire. When the tail lights are on, power comes into the dim filament, can't get to ground, so it goes into the bright filament out the other wire across to the opposite brake light, through its filament to ground. So the tail light works with no ground at the RH light with the brake lights off.
Now. When you step on the brake, there is power introduced to the bright filament on its wire, but it can't get to ground, so it doesn't light. The tail light now has +12V on both sides of its filament so it goes out.
You have a bad ground on the RH light. Could be the connector on the back of the "oval" light. Spread the pins out a little, or smoosh the female connector in the plug a little for a better connection.
Old Oct 8, 2016 | 01:40 PM
retiredsparky's Avatar
retiredsparky
I agree. Remove ground connection, sand rust/paint to clean steel, clean terminal, add some grease, use new bolt, washer, lock washer. Look at terminal for wire corrosion inside connector. I have had to re-tap the bolt hole to clean out the rust.
Old Oct 9, 2016 | 02:21 PM
hydro man 17's Avatar
hydro man 17
Just spit-balling here. Had a similar isue years ago and it turned out to be a bad turn signal switch. When you have one bulb doing different functions they are switched through the turn signals. When the contacts in the swich fail or break all kinds of wierd stuff happens.
Old Oct 9, 2016 | 02:31 PM
79jasper's Avatar
79jasper
Battery terminal stuff would work well for this.
Tonto Kowalski
33
May 10, 2018 03:29 PM
cherrybomb37
Oct 8, 2014 10:16 PM
furyus
Oct 20, 2009 12:07 AM
mike28
Jan 2, 2008 11:14 PM
shane43028
Aug 20, 2003 10:15 PM
