Bubbles in fuel filter
Old Oct 4, 2016 | 12:10 PM
72camper special's Avatar
72camper special
I have a 1972 ford f250 camper special with the 6.4l 390. I have replaced the fuel pump, fuel filter, plugs and wires, air filter, oil and filter as well as the Gas lines from the pump to the carb . But now I'm having the issue of getting tiny bubbles in the fuel filter and the filter drains and never fills back up unless I prime the carb a couple times but it only does this after the truck has heated up and has been driven a short distance.
What could this be?
Old Oct 5, 2016 | 07:46 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds like vapor lock, but it never goes away after it cools down?
Old Oct 5, 2016 | 09:18 AM
'65Ford's Avatar
'65Ford
Does it affect your engine when starting or running? I'm not seeing how bubbles in a fuel filter for a carbed motor affect anything.
Old Oct 5, 2016 | 01:27 PM
72camper special
Not when it's starting other than having to prime the carb to get any kind of fuel to the filter but when this happens and it's running it will spudder and die out and I will be stuck on the side of the road for 25 to 40 min before it will run again
Old Oct 5, 2016 | 01:38 PM
'65Ford's Avatar
'65Ford
The bubbles may be symptoms of another problem...like a leak in the fuel line. Todays gas rots out fuel hose. Could try replacing all your rubber fuel hoses.
Old Oct 5, 2016 | 02:12 PM
krewat's Avatar
krewat
If you take the air cleaner off, is there fog rising from the carb?
Old Oct 5, 2016 | 02:22 PM
72camper special
No it all seems normal to me and it runs great until it runs out of fuel
Old Oct 5, 2016 | 02:41 PM
krewat's Avatar
krewat
The pickup in the tank is clogged.
Once the vacuum in the fuel line builds up to a point where it starts sucking air from somewhere, you're done.
Old Oct 5, 2016 | 03:23 PM
'65Ford's Avatar
'65Ford
I guess it's possible to have a clogged pickup. Kinda wonder what's in the tank if that's the case.
If the rubber hoses between the tank and the fuel pump haven't been changed in the last 10 years then it's definitely time.
Old Oct 5, 2016 | 03:45 PM
krewat's Avatar
krewat
Come to think of it, do you have a vented gas cap?
Old Oct 5, 2016 | 04:45 PM
72camper special
No its the locking cap
Old Oct 6, 2016 | 12:19 PM
72camper special
And also would it be alright if it has a 1/4 fuel line from pump to carb and the 3/8 fuel line from carb back to tank selector and to both tanks? Or would it be best to run 3/8 all the way
Old Oct 6, 2016 | 12:23 PM
krewat's Avatar
krewat
usually 5/16" or bigger.
I wonder if the unvented cap is creating vacuum in the tank and eventually the old hose is letting air in somewhere.
Could also be the tank selector leaking air.
Old Oct 6, 2016 | 12:50 PM
72camper special
Who sells the tank selector I have called auto zone and o' Reillys and neither of them carry it
Old Oct 6, 2016 | 03:26 PM
krewat's Avatar
krewat
just bypass it to test it
