7.3 wiring issues
Old Oct 3, 2016 | 05:13 PM
Hubs_duramax's Avatar
Hubs_duramax
7.3 wiring issues
hey guys,
i just bought a 91 f250 7.3 5 speed
does anyone happen to have a diagram of the rear of a fuse block along with a wiring schematic? someone went through and cut wires and pulled wires out of the fuse block, now im trying to piece it back together
Old Oct 6, 2016 | 03:29 PM
Fixnstuff's Avatar
Fixnstuff
The following images are from the 1987 Ford Shop Manuals, specifically the 'Electrical and Vacuum Troubleshooting Manual.' 1987-91 were the same design series 'Eighth Generation' so the schematic should be the same for your truck's original wiring, with the possible exception of any fuse circuit related to the E4OD transmission introduced the following year, 1988. The 87 manuals do not include the E4OD, I don't have that transmission so I don't know if there is a related circuit in the fuse panel.
You should be able to figure everything out with the following:
Old Oct 6, 2016 | 11:43 PM
Hubs_duramax
Awesome thanks!
Pirublues
Aug 13, 2025 04:06 PM
John Wall
May 26, 2018 04:21 PM
cheeriup
37
Mar 17, 2017 04:12 PM
RV_Tech
All Things Towing
16
Jun 24, 2015 03:44 PM
rleptrone
1997 - 2003 F150
Aug 6, 2003 12:01 AM
