WD Hitch
Old Oct 2, 2016 | 06:12 PM
Owenage's Avatar
Owenage
WD Hitch
I'm fairly certain this may have been covered, however I want to know for sure my options. I am currently towing a Jayco Eagle 314BHDS with a weight of around 9500lbs. As the new truck (F-350 Platinum) will not work with my current hitch setup, I'm wondering what the best options are available on the market. Anyone else currently looking to replace the WD/ Sway Control setup? Also any idea of 3" receiver options for a WD hitch coming?
Cheers,
Joe
Old Oct 2, 2016 | 06:33 PM
Canwan's Avatar
Canwan
I have a dumb question, why won't your current setup work with the new truck?
Old Oct 2, 2016 | 06:53 PM
Owenage's Avatar
Owenage
Not a stupid question at all. The current setup will not work due to the height difference of the truck. My current truck is a 2016 F-150 and as you can see from a below thread its a big difference in required ball drop. By the way my current WD is a Reese 12,000lb.
Old Oct 2, 2016 | 06:55 PM
Canwan's Avatar
Canwan
Aren't all reese adjustable? You can buy just the shank.
Old Oct 2, 2016 | 06:59 PM
wb6anp's Avatar
wb6anp
Weight Distributing Shanks
new shanks for Reese Hitches
Old Oct 2, 2016 | 07:00 PM
Owenage's Avatar
Owenage
You are correct. I have checked a few places locally here in Calgary and haven't been able to find a supplier that stocks them. Also I haven't been very happy with this setup to be honest. It's wicked loud, so I guess any reason to replace it with something "better" I will jump all over it.
Old Oct 2, 2016 | 07:02 PM
Canwan's Avatar
Canwan
The 'Helsley' is regarded as the best anywhere I have read over the years.
Reese shanks shouldn't be hard to find. I know Grandwest out of Saskatoon is a supplier for them. I'd be surprised if they didn't have stock.
But I understand completely. I have never been overly impressed with anything from Reese.
Old Oct 2, 2016 | 07:05 PM
Owenage's Avatar
Owenage
I have heard of that hitch. Seems like a pricey replacement, but well worth it. Any idea who sells it here in Canada?
Old Oct 2, 2016 | 07:06 PM
Canwan's Avatar
Canwan
I am not sure who if anyone carries it in canada but they have a 'find a dealer' link on their site.
Old Oct 2, 2016 | 07:08 PM
DL222's Avatar
DL222
Check out this brand
Equal-i-zer® Hitch - The ?American Original? with 4-Point Sway Control? and Weight Distribution
Old Oct 2, 2016 | 07:27 PM
wb6anp's Avatar
wb6anp
Yes the Hensley is wonderful, and wonderfully expensive, I had one in the past great sway control. Also check on Pro pride, same type of hitch as Hensley, but a little less money. They are both also Heavy hitches 100 lbs or more.
Old Oct 3, 2016 | 01:02 AM
Robmiezer's Avatar
Robmiezer
I will throw in my 2 cents. You won't need a weight distribution hitch. Look for a new 3" receiver and ball, cheaper and much lighter.
But, it will not address the "mechanical" sway control.
Old Oct 3, 2016 | 02:01 AM
OkieSweetness's Avatar
OkieSweetness
Personally, I have a propride and it is by far the best hitch I have ever owned. I don't think it will be necessary on my new 2017 F350 but I will most likely tow with it anyway. Certainly worth a look, but for me a 70K truck, and 20k trailer, a 2k hitch was just a drop in the bucket.
Old Oct 3, 2016 | 08:57 AM
Rasty1's Avatar
Rasty1
My understanding about the hitches being intragrated into the frames, we don't need sway control.
Old Oct 3, 2016 | 09:07 AM
fordmantpw's Avatar
fordmantpw
With the hitches integrated into the frame, you don't need weight distribution. Sway control is completely separate, and depending on the trailer, you may still need it.
