'53 Ford Revival
#31
Shawn,
That old charger would be the best one to use for parts cleaning using electrolysis.Yes a big plastic stock tank might work good. It is a project getting one of these tanks set up but they can do a lot of cleaning for you too. The new chargers are sometimes too smart and shut off all the time.
Thanks for posting. Lots of moves ahead of you, hang in there!
Regards,
Chris
Regards,
Chris
#33
on
Shawn... you certainly have your work cut out for you... mine wasn't quite so bad and having a good friend who is a commercial painter with heavy duty sand blast equipment is a plus... You're doing it the right way... one bite at a time.. don't get too many pieces started and not finished. It will overwhelm you. good luck and keep at it.. and add my welcome to FTE.
john
john
#34
Shawn,
We are all different on how we attack this kind of project. One of the biggest things is to take and save/store pictures as you go. At least that works for me. I try to clean some of the stuff as I move along as too. The number of parts can be overwhelming. Sandblasting that frame looks like it would be a good option and save you a bunch of dirt in the eyes! Glad to hear you have your son involved too!
I currently have a off topic (farm) tractor project apart, and its going to be a year before I can get the time and the funds to get it back together.
Your doing good!
Regards,
Chris
Your doing good!
Regards,
Chris
#35
Finally got the engine out and getting the frame cleaned up to coat. Holidays have slowed down progress for sure, but still moving.
Did manage to pick up a 69 f100 for parts, but it appears my son has decided that it is his project. So helping him get that one running, waiting for a carb kit to come in so we can put the carb back together and see if it will kick over.
Hope everyone had a wonderful Christmas and has a happy new year.
#36
#38
Abe you are correct, that is a 80 bed on the truck, we might have to hit some salvage yards and see if we can get a different bed for it, it needs a hood and around the drip rail is rusted through. He's taken a good interest in that truck so for now I will let him work on that one, hopefully when the carb gets back together it will run and he can have fun with it.
#39
Yes wanting to get a blast cabinet and blaster next, wire wheel works, just noisy and slow. Almost have the front frame completely wire wheeled, just got some nooks and small areas to get into with the small ones and some wire brushes. Few more bolts that seemed to have nothing, just in the frame, think one was the frame ground.
#40
#42
The pins are pretty hard. An air hammer shouldn’t phase them. They may be badly worn and not lining up to push out. You might try to put the wheels slightly on the ground and try to align the spring to the shackle. You did take the pins out that hold the pins in didn’t you.
#43
Got the front end taken off and getting cleaned up. Frame wire brushed and ready for painting, Saturday was a nice day except for the wind highs around 76 with a cold front coming in Sunday. So figured I would go ahead and get the frame painted so I can get things put back together after they are cleaned. Using por15 and top coating the outside of the frame with a light ford grey paint.
#44
#45
Spring shackles and pins look pretty good, there is some noticeable wear. Leaf springs have been wire wheeled and will paint them on the next warm day. Then to tackle the I-beam and rack and pinion, king pins and all still feel tight so slowly making my way through the front end.
