How much oil?
Old Oct 1, 2016 | 07:58 PM
mxer0022's Avatar
mxer0022
How much oil?
Ok guys I have a 460 that I just rebuilt and I deleted the oil cooler and replaced it with a two filter relocation kit. I put 7 quarts of oil in to it knowing stock it takes 6. The extra FL1A filter holds almost a quart the I figured what was held in the lines would compensate for the rest of the quart. Well I took my truck out and had a huge oil leak that I determines was due to it being overfull and slinging it out the dip stick hole in the oil pan (I forgot to put the o-ring on). So as of now it is still reading over full.
Has anyone added the summit 2 filter relocation kit and deleted the oil cooler and how much oil do you put in?
Old Oct 2, 2016 | 06:42 AM
'89F2urd's Avatar
'89F2urd
It shouldn't be spitting oil from half a quart over full. I'd check your oil filter for seal....if it's really coming out of the dipstick hole then you should check pcv valve and do a blowby test.
Old Oct 2, 2016 | 01:13 PM
mxer0022's Avatar
mxer0022
Well I'm not sure it was only half a quart over full. Cause I checked it after it all blew out and it was still a half to a quart high.
My oil filters are mounted where on the side of the engine compartment where the factory airborne usually sits.
Old Oct 3, 2016 | 07:24 AM
'89F2urd's Avatar
'89F2urd
A little bit of oil makes a huge mess. If you lost a quart it'd seem like the Exxon Valdez.
srteach
Nov 3, 2013 09:08 PM
2112
Dec 9, 2012 11:35 PM
Itsmejoe231
1997 - 2003 F150
Aug 31, 2005 04:11 PM
Petiboy
1997 - 2003 F150
Oct 30, 2003 07:49 AM
proeliator
Jun 9, 2002 12:15 AM
