2012 F-250 eliminate cold start high idle
currently have 3" single exhaust, no cats and a super 44 flowmaster, sounds great when warm and is quiet on startup, but in the morning its twice as loud. ive been told the VCT has the cams in the fully retarded position on cold startup making it loud, just wondering if there is a way to program it so it doesnt go through this cycle when cold
useless tech support at diablo, pretty sure they didnt even read the question.
Description: I am looking to disable the high idle on cold startup, just wondering if its possible with a custom tune.
Diablo Tech Support <tech@diablosport.com>
Oct 12 (6 days ago)
to me
You can set the idle high, but it will not change once the trucks warms up.
re: i want the truck to idle normal on a cold start
Diablo Tech Support
Oct 13 (5 days ago)
Lowering the idle does not always work as the manufacturers sometimes set a min idle speed that cant be lowered due to emissions concerns.
Thanks
re: When the truck is warm, it idles at 600 at startup, when cold its around 1200 for a minute or so and is pretty loud for where I live. all I want to do is get a custom tune so when its cold it will start up and idle at normal speed. Im aware the 2 idle adjustments on the i1000 will not effect whatever ford has programmed the truck to do on a cold start.
they didnt respond after that, they were supposed to have excellent tech support and even send you custom tunes after sending them data logs, they refuse to do that and told me to go to a local shop when I tryed to get one last year.
Oct 12 (6 days ago)
to me
Diablo Tech Support
Oct 13 (5 days ago)
Thanks
lawdawg79
10-19-2015 09:14 AM
