Trailer hitch Height
Old Sep 30, 2016 | 09:50 AM
Kenv's Avatar
Kenv
Yeah Nimrod....I think a lot of guys will do adjustable...but I was waiting for the adjustable with the 3" shaft. I don't think anyone has one available but they are working on them. I didn't want to buy the 2 1/2 shaft size adjustable and then a month later the 3" shaft comes out!!
Old Sep 30, 2016 | 10:32 AM
Nimrod's Avatar
Nimrod
Are all the F250 SD equipped with the 3" ball mount or is that a special package?
Old Sep 30, 2016 | 10:42 AM
wb6anp's Avatar
wb6anp
You have to have the HD trailer tow package for the 3" hitch.
Old Sep 30, 2016 | 11:32 AM
Rasty1's Avatar
Rasty1
Any measurements with 18" tires for the F250?
Old Sep 30, 2016 | 12:14 PM
wb6anp's Avatar
wb6anp
wow to keep my current hitch Ill need to go with a 8" drop, $114.00 for the draw bar. So the question is should I buy that basically for the Anti Sway features, or go with an adjustable like the weigh safe (299) and go without the anti sway.
Old Sep 30, 2016 | 03:39 PM
Nimrod's Avatar
Nimrod
I see. I have a trailer towing package not sure its the one you are talking about. Doesn't say HD.
Old Sep 30, 2016 | 03:54 PM
wb6anp's Avatar
wb6anp
thats probably it then
Old Sep 30, 2016 | 04:51 PM
Kenv's Avatar
Kenv
You'd have to look at your options to see if you got 535. HD Tow. There are a lot of other "tow" related options and standard stuff listed on the order guide....but you only have the HD Tow Package if you got option 535.
Old Sep 30, 2016 | 07:39 PM
Nimrod's Avatar
Nimrod
Nope. Mines under preferred Equipment package 608A.
Old Oct 1, 2016 | 06:24 AM
Xwild's Avatar
Xwild
That's just the regular tow package.
Old Oct 1, 2016 | 07:34 AM
HouseMouse's Avatar
HouseMouse
The HD tow package is a upgrade or a special order. I got it. 3-2'5-2". Comes with the insert bushing. Haven't got to mine yet.... F350, CC, 4x4, Long bed. Looking at a 3" when available with a 4-6" adjustable. Not exactly sure yet.
Old Oct 1, 2016 | 07:58 AM
Rasalas's Avatar
Rasalas
If you purchased an F250 SD you technically will not need the 3" hitch. The 2 1/2" is more than adequate for anything you can bumper tow with that truck. I installed a 2 1/2" on my '01 and can handle 9 ton trailers with up to 2000 lb tongue weight. Of course it is nice to have the reserve towing capacity if the need should ever arise but more weight would require upping the spring package in one way or another, such as the heavy duty tow package does for you.
Old Oct 1, 2016 | 08:04 AM
  #28
Rasalas's Avatar
Rasalas
The F 350 comes with the 3" receiver. Welcome back by the way. The 3" ball mounts should start to populate around November according to the two manufactures I have contacted already. SEMA show at that time is a showcase of aftermarket and conversion products and the more popular brands strive to have their wares available at that time. Geny Hitch said that if I needed one earlier I should contact them directly and they would see if they could get one out to me as soon as possible. No need for me for obvious reasons.
Old Oct 1, 2016 | 10:23 AM
  #29
HouseMouse's Avatar
HouseMouse
Yes, Thank You, it's good to be home. 4000 on the Oh-Doh now. It's a beast. Didn't see another registered 2017 on the road the whole time.
Old Oct 1, 2016 | 11:05 AM
  #30
wb6anp's Avatar
wb6anp
I have yet to see one in he wild, which is strange since my local dealer is supposed to be the #1 volume dealer in the country. Galpin Ford - Galpin Ford Earns Title of No. 1 Volume Ford Dealer in the World for 25th Consecutive Year
