brake warning light flickering
Old Sep 28, 2016 | 05:57 PM
jthuston's Avatar
jthuston
Hi Guys,
I've been experiencing an issue with my 1985 F-250 4X4 where the brake light in my instrument cluster sometimes comes on at a hard stop; when it does, pushing down or letting up on the pedal will make it go off, and returning it to the same spot will make it come back on. I've replaced the master cylinder and proportioning valve recently, and have bled the brakes by the book multiple times. The brake feel as good as ever, and i'm getting no air bubbles when i bleed them.
Any ideas? I'm stumped.
-James Huston
Old Sep 28, 2016 | 06:12 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
Originally Posted by jthuston
Hi Guys,
-James Huston
You replaced the master cylinder with what? meaning from where, what brand ?
Old Sep 28, 2016 | 09:40 PM
Montync's Avatar
Montync
Did you bench bleed the master cylinder? You have to make sure all the old fluid is out and the master is bled. Air may be getting in somewhere triping the warning light. Also lift up the parking brake pedal by wire or string ( I had an issue with it had to adjust the parking break hard breaking would trigger the brake light). Someone else may be able to help you test the prop valve.. What I would do would go something like this (going by a test for a 1 wire)
Set a multimeter to continuity.
if its a two wire, ground one prong to a cleared (sanded spot) on the prop valve
touch one lead to the prong on the male connector of the valve
have someone press the breaks.
if it beeps you have air in the line
if it does not move the the next male connector on the valve
have someone press the brakes.
if not look for loose worn wiring the may be rubbing triggiring the light when braking
Old Sep 29, 2016 | 06:44 AM
jthuston's Avatar
jthuston
The master cylinder was a remanufactured one from Autozone. I'll try testing the proportioning valve today.
-James Huston
Old Sep 29, 2016 | 07:17 AM
Franklin2's Avatar
Franklin2
If you have a diesel, you have a vacuum switch that is also hooked to the brake warning lamp.
Old Sep 29, 2016 | 06:28 PM
jthuston's Avatar
jthuston
No diesel here, just your everyday 300. I wasn't able to test the proportioning valve because it decided to rain cats and dogs here, but I hope to rule that out tomorrow.
-James Huston
Old Sep 29, 2016 | 06:31 PM
Franklin2's Avatar
Franklin2
-James Huston
Just take the wire off the valve. Also check that wire. If it rubs against metal anywhere and the insulation is rubbed through, the light will come on. All you have to do is ground that wire and the light comes on.
Old Sep 29, 2016 | 07:05 PM
jthuston's Avatar
jthuston
I do know now that taking the lead off of the proportioning valve stops the issue; I'll look over the wire in depth tomorrow and report back.
-James Huston
Old Sep 30, 2016 | 01:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The Brake Pressure Differential (some people call it a proportioning) Valve Warning Lamp Switch was a troublesome turd from day one.
D5AZ-2B264-A (replaced D0AZ-2B264-A) .. Warning Lamp Switch / Available from Ford & auto parts stores.
1980/89 F100/350 & Bronco / 1980/2001 Econoline / 1990/96 F250/350.
1970/78 misc. FoMoCo Passenger Cars / 1979 LTD II(not an LTD!)/Ranchero/Thunderbird/Cougar/Mark V.
Orlen
Apr 20, 2019 10:49 PM
78fordguy
Aug 8, 2014 10:33 AM
wagners
Apr 20, 2013 09:46 PM
dazman
1978 - 1996 Big Bronco
Feb 9, 2004 10:21 PM
Avanti
Aerostar
Apr 23, 2002 04:52 PM
