1978 - 1996 Big Bronco
Brake Warning Light!
Old Feb 9, 2004 | 11:00 AM
dazman's Avatar
dazman
I was having a problem with the warning light coming on about a week after I bed the brakes. So I replaced the master cylinder and it has been about a month now and the brake pedal travel has increased and the warning light came on again but I was able to reset it by pressing on the brake pedal.
Everytime I bleed the brakes it seems as though I cannot get all the air out on the driver's side.
Could my proportioning valve be going?
Thanks
Old Feb 9, 2004 | 02:14 PM
BillyBob69's Avatar
BillyBob69
You could also have a bad slave cylinder. I had a similar issue and wound up replacing the slave cylinder at each wheel. Not too expensive and fairly easy if you are somewhat mechanically inclined.
Old Feb 9, 2004 | 08:58 PM
dazman's Avatar
dazman
I was thinking about doing that because it is only on the one side that gives me air when bleeding the brakes. Funny it isn't leaking at all though.
Old Feb 9, 2004 | 10:21 PM
BillyBob69's Avatar
BillyBob69
It wont always be a visible leak...the heat from raking can boil the fluid and it will just soak in or spread arounnd the wheel or just throw off.
