5.4 SuperCrew should be a 9.75.
The axle code will not tell you which rear end you have, only the gear ratio and if you have limited slip or not.
If you have 10 bolts and squarish cover, it is a 8.8, if you have 12 bolts and trapezoid shape, it is a 9.75 (technically a 12 bolt trapezoid shape could also be a 10.25, but not found stock on the Supercrew, only the F250 LD/ 7700).
edit: made a quick pic with the 2 different covers.
