7.3 fuel pressure relief valve code???
Old Sep 28, 2016 | 05:43 AM
Sky_jumper's Avatar
Sky_jumper
If the fuel relief valve is stuck open would it possibly throw a P1316 code?
Thanks Alex
Old Sep 28, 2016 | 07:32 AM
mueckster's Avatar
mueckster
Very doubtful. Low fuel pressure/volume would not cause an electrical code for the injector/IDM wiring. The PCM has no real way of monitoring fuel pressure. Low fuel volume could, however, affect injector ICP and possible throw a different code.
Old Sep 28, 2016 | 07:54 AM
pirschwagon's Avatar
pirschwagon
DIAGNOSTIC TROUBLE CODE (DTC) P1316 INDICATES THAT CODES ARE STORED IN THE IDM
Possible causes:
a. Injector(s) or circuit(s)
b. Open or shorted IDM enable circuit
c. Open/short in EF circuit
d. Open/short in FDCS circuit
e. IDM relay
f. IDM powering circuits
g. IDM
h. PCM
Check for other codes.
Key on, engine off. (KOEO)
Perform KOEO On-Demand Self-Test.
P1316 OR P1670, CHECK FOR AN INTERMITTENT OPEN CIRCUIT
KEY OFF.
Install breakout box, leave PCM disconnected.
Disconnect IDM.
Check for intermittent open in the following circuits:
Measure resistance on (FDCS) Circuit 821 (BR/O) between IDM connector Pin 17 and PCM Test Pin 95.
Measure resistance on (EF) Circuit 818 (GY/W) between IDM connector Pin 4 and PCM Test Pin 48.
Grasp the harness close to the IDM connector. Wiggle, shake the harness while working your way back to the PCM, while looking for a spike on the DVOM.
Description The IDM provides the EF output signal to the PCM to confirm that proper timing/duration of fuel delivery command signal (FDCS) was received. Additionally, the EF signal is used to send diagnostics of the IDM and injectors (electrical) to the PCM.
DTC Description
P1668 = PCM-IDM diagnostic communication error
P1670 = Electronic feedback signal not detected
P1316 = Indicates that IDM DTCs are stored within the IDM
DTC P1668 and P1670 indicates that a communication error has occurred between the PCM and the IDM.
Possible causes:
a. Open fuse
b. IDM relay
c. Open or shorted IDM enable circuit
d. Open/short in EF circuit
e. Open/short in FDCS circuit
g. PCM
h. Check for other codes.
KOEO:
Perform KOEO On-Demand Self-Test and retrieve Continuous DTCs.
CHECK CIRCUIT 818 (GY/W) FOR OPEN
Install breakout box; leave PCM disconnected.
Disconnect the IDM harness connector.
Measure resistance on Circuit 818 (GY/W) between PCM Test Pin 48 and IDM harness connector Pin 4.
Key on, engine off. Measure for voltage on Circuit 818 (GY/W) between PCM Test Pin 48 and battery ground.
Turn ignition switch to OFF. Measure resistance on Circuit 359 (GY/R) between PCM Test Pin 91 and IDM connector Pin 2.
CHECK IDM POWER
PCM connected, IDM disconnected.
KOEO. Measure voltage between IDM connector Pin 14 and battery ground.
CHECK IDM GROUND
KEY OFF. Measure resistance between IDM connector Pin 26 and battery ground.
Old Sep 29, 2016 | 09:00 AM
Sky_jumper's Avatar
Sky_jumper
I have my work cutout for me and thanks.
Old Sep 29, 2016 | 06:36 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
That P1316 codes should not be related to fuel pressure at all. Get a scan tool plugged in that can do an injector buzz test. That should tell you what is causing the P1316 code. All that codes means is that there are IDM codes detected. Doing the buzz test will normally pull those codes.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
stangclassic66
13
Oct 14, 2023 04:54 PM
Bvill01
17
Oct 15, 2017 10:37 PM
scottddove
Jul 31, 2015 02:02 PM
Lerch7.3
Jun 24, 2015 07:53 AM
wildspirit78
Dec 26, 2007 02:52 PM
