Won't start off key only pull start
Old Oct 7, 2016 | 11:08 AM
daniel1997psd's Avatar
daniel1997psd
Originally Posted by 79jasper
Also parts stores testing a starter means nothing.
Just because it spins doesn't mean it's good. May not have enough go juice inside, could be drawing too many amps, etc.
Batteries first.
Ok so I just put a brand new starter in it and it was cranking then all of a sudden it made a snap noise and now it won't crank at all... so something is shorting it out ? Bad fuse? Idk!
Old Oct 7, 2016 | 11:45 AM
knottyrope's Avatar
knottyrope
engine wont turn/spin at all?
put 1/2 breaker bar on front crank pulley and see if it can turn in either direction
might have to pull inspection plate off and look inside
did it sound mechanical or like a fire cracker pop?
Old Oct 7, 2016 | 01:24 PM
daniel1997psd
I fixed that a wire fell apart I put a new one on now it spins great but still no fire how can I check the pcm ? Or could it be something else
Old Oct 7, 2016 | 04:51 PM
Shawn MacAnanny's Avatar
Shawn MacAnanny
With a new Ford cam sensor, new 1000cca batteries, new battery cables, new Ford ipr, watching with auto enginuity my engine only cranks over at 150 to 160rpm and fires right up.
You need to test the batteries and make sure you have good battery cables. Really you should own auto enginuity it's saved me so much time in guessing.
Old Oct 7, 2016 | 07:32 PM
daniel1997psd
Ok so now when you pull it off it won't will idle for a little but it revs up and down (lobbing I think) but then it levels out and shuts off so I tried to pull it again and it would only run if you we accelerating but as soon as you let off gas it shuts down so is that hpop some where ???
Old Oct 10, 2016 | 01:38 PM
knottyrope's Avatar
knottyrope
lobbing is normal if there is air in system still
Next time just hold throttle to 1000 RPM and let it run a bit
What voltage is batteries when cranking and GPs on?
Old Oct 10, 2016 | 07:07 PM
Dr. Johnson's Avatar
Dr. Johnson
Is the WTS light coming on?
basic checklist
*batteries?
*starter?
*WTS light comes on like it's supposed?
*Tach is reading correctly? (CPS)
*Fuel bowl full?
If all these check out, you're gonna need more info from the computer..
AutoEnginuity or Forscan, Forscan is free if you have a laptop. You just need a OBD2 to USB adapter.
If it fires up but is running rough and dies, I'd suspect oil or fuel supply issue. It's all guessing until you scan it.
Old Oct 11, 2016 | 07:27 AM
daniel1997psd
basic checklist
*batteries?
*starter?
*Fuel bowl full?
That's all good but what is the CPS
Old Oct 11, 2016 | 07:59 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CPS-Cam Positioning Sensor.
Old Oct 11, 2016 | 09:52 AM
daniel1997psd
oh ok and it will run even if that's bad just not start?
Old Oct 11, 2016 | 10:02 AM
CampSpringsJohn
No. If that is bad, it will not run. The tach gets its readings from that sensor. Trucks have been known to shut down while going down the highway when one of these fail. Many of us keep a spare in the glovebox, along with a 10mm wrench to change it.
Old Oct 13, 2016 | 10:10 AM
daniel1997psd
Update I think the HPOP is bad or the ipr i was driving the truck around the other day and it was kinda missing a little and down on power about 1000 rmps then the check engine light came on and it is way down on power over 1000rpm is this the HPOP or IPR ? I did have to pull start it to get it running.
Old Oct 13, 2016 | 10:19 AM
  #28
Jarrett Campbell's Avatar
Jarrett Campbell
How is your oil level?
Did you ever figure out what snapped?
Have you tried starting it by jumping the solenoid on the PS fender?
Do you have any way to read live data? It would behoove you to get us accurate data so we don't chase our own tail or yours.
Old Oct 13, 2016 | 10:45 AM
  #29
daniel1997psd
the snap way the starting fuse fixed that the screw is striped so i cant look at oil level. i have jumped the solenoid and it doents work. what kind of data tracker should i get i don't have much to spend.
Old Oct 13, 2016 | 10:50 AM
  #30
knottyrope's Avatar
knottyrope
what is engine oil level?
