49 merc flathead
Old Sep 27, 2016 | 09:52 AM
zrae's Avatar
zrae
Originally Posted by ALBUQ F-1
It's a Canadian thing. If we can get a picture of the lines to/from it, we can confirm whether it is a factory full-flow system or not. I don't think it is, but there is also a Canadian bypass filter that is taller than the typical US type. I believe it was a Canadian military thing, to standardize on filter elements.
I'll take some more pics of the truck today sometime and post them.
Old Sep 27, 2016 | 09:55 AM
zrae's Avatar
zrae
Originally Posted by Doc
What's that green plug between the #5 and #6 plugs? Some sort of block heater (I don't see how) or a sender unit?
Yeah it's a block heater. It must be a farmer thing. Another neat thing I found in the glove box was this old school tire inflater. You pull a spark plug out and put this in place of the plug and pump up your tire. I think it has some sort of check valve in it.
Old Sep 27, 2016 | 10:13 AM
Doc's Avatar
Doc
That's pretty cool. It has some value. Here's one for $50 on ebay.
Vintage Schrader 8888RG Spark Plug Tire Pump Inflater Gauge Air Compressor | eBay
Old Sep 27, 2016 | 11:45 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Those are still popular with motorcyclists
Old Sep 27, 2016 | 03:16 PM
KirkF's Avatar
KirkF
The green plug is a block heater.
My Canadian 1950 Ford Truck Engine had identical ones on both heads.
It replaces one of the head bolts.
I wonder if anyone makes those anymore.
Kirk
Old Sep 27, 2016 | 07:38 PM
zrae's Avatar
zrae
This is the best pic I could get. Hopefully it helps.
Old Sep 27, 2016 | 07:41 PM
zrae's Avatar
zrae
Old Sep 27, 2016 | 07:45 PM
zrae's Avatar
zrae
Not really, the spark plug is over the valves. Even doing it from the bottom (pan off) is kind of difficult. Merc crankshafts have some markings but in typical Ford fashion there are enough exceptions that direct measurement is the only sure way.
From what I see in the pictures, I'd be surprised if it's a Merc. I'd be curious to know what's marked on the dipstick, see below. Also, does the oil pan have the large (truck-style) cleanout?
Here's a couple pics of the oil pan clean out and the dipstick. It turns out my grandpa bought the truck in the early to mid fifties so it was slightly used when he got it. It may have been swapped out in the early years. My uncle said today that as far as he is aware it was never rebuilt or swapped out. But there are this 5 or 6 years before they got it.
Old Sep 27, 2016 | 10:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Thanks for the pics. You have a standard Canadian bypass oil filter, not a full-flow system, as far as I can see. Does the line from the bottom of the filter canister go down to the bottom of the block, just above the oil pan?
I guess even dipsticks are different on Canadian engines. You do have a truck oil pan. So it's likely that at some point at least the heads were swapped on it, maybe the whole block, but without tearing it open, no way of knowing.
If the truck hasn't been in regular use, personally I think it's real instructive to take the intake manifold off to see what kind of crud is in the engine. It isn't that hard, don't even need to drain the coolant. The only hassle is removing the fan and generator, and to a lesser degree the fuel pump. The lifter valleys tended to collect a lot of sludge back in the days of leaded gas and non-detergent oil. If it's really bad, it definitely is worth cleaning out. No amount of running detergent oil, Marvel Mystery Oil, diesel, etc. will clean it out. There also may be a mouse nest in there! I took one apart recently that was full of acorns and the stuffing from the seat cushions.
Old Sep 27, 2016 | 10:46 PM
zrae's Avatar
zrae
I believe the line goes to the bottom of the block just above the pan. Once I can get the truck registered in my name I will be tearing it apart and starting the resto on it. I plan on pulling the motor apart and re-gasketing the whole thing. As long as everything looks okay when I tear it apart. As it sits now though it runs nice and smooth. No hesitation when I give it gas. No sound of any grinding or anything either which is awesome. I am looking forward to getting started on the project. Now it's time to convince the wife that she does NOT need to park in the garage for the winter. I think that's a battle I am going to lose.
Old Nov 8, 2016 | 10:07 PM
tip49's Avatar
tip49
My money is on the wife
[/QUOTE] Now it's time to convince the wife that she does NOT need to park in the garage for the winter. I think that's a battle I am going to lose.[/QUOTE]
I am used to parking all but one vehicle in the snowbank for the winter.
Tom
bill_g
53
Jan 16, 2017 11:46 AM
50mercman
Mar 30, 2016 06:53 PM
WARDNEAL
54
May 2, 2012 10:09 AM
oscarxyz
Jan 24, 2006 07:33 PM
jpb222
Flathead V8 & Flathead 6
Sep 4, 2002 03:08 PM
