Travel Trailer
Old Sep 29, 2016 | 02:57 AM
  #31
Pwrgeek's Avatar
Pwrgeek
Originally Posted by Krazee Matt
Yukon makes good stuff. It's more about quality and the price reflects it for gears, those're something I have never, ever, skimped on.
A first rate install shop is the second piece. Inexperience leads to bad things happening. Those bad things can happen at idles speeds, or they can happen at, oh, say... 65mph while you're towing your first Chevelle and the rear wheels suddenly decide they don't want to turn anymore. I owned that car all of 13 hours and it got totaled.
4.56 seems about on par to reach a desirable towing ratio with 37's as well as keep things happy turbo wise without too much gentle grade lugging and spiking EGT's. I haven't followed this whole thread, so I don't know if a tuner is already installed or not. A good one (cough, Gearhead, cough) plus gears will making towing a whole hell of a lot nicer one everything across the board. 6.0 cooler as well, blah blah blah.
Yes Mdavidson, both axles need to be regearedto the same ratio. You can do the rear first and then the front, but you will NOT be able to use 4wd until the axles have matching ratios. So if budget is a concern that's one way to space it out over some time. Just be damn sure 4wd is never engaged because things will bind and you'll start grenading parts real quick in potentially really expensive areas.
If you do decide to do gears one axle at a time I'd heavily suggest dropping the front driveshaft out. It's 8 bolts to take it off and would ensure you didn't accidentally drop into 4wd (which could get really interesting at any speed with mismatched gears).
Old Sep 29, 2016 | 06:04 AM
  #32
WE3ZS's Avatar
WE3ZS
I just leave my 4X4 vacuum solenoid unplugged to keep my miss matched axles from making bad noises. 3.73 front and 4.88 rear for the past 4 years, man I really am lazy........
Old Sep 29, 2016 | 07:15 AM
  #33
ExPACamper's Avatar
ExPACamper
Originally Posted by emsteere
Very nice! Uhm...did you Excursion come with bikes on top? I've *seen* the top of mine, but barely
How do you load and unload up there?
Old Sep 29, 2016 | 12:39 PM
  #34
emsteere's Avatar
emsteere
I keep a short, 3-step ladder in the truck. It is a matter of good balance to climb a step stool while military pressing a bike. After a couple times, you get good at it, but it certainly gives you incentive to own lightweight bicycles.
On the other hand, a full bike mount, without removing the front wheel is far easier to load. When I am not towing, I use a hitch rack.
Hdslider
6.7L Power Stroke Diesel
May 11, 2012 03:16 PM
Cruiseomatic
All Things Towing
Nov 30, 2011 01:46 PM
JaySVX
Mar 23, 2009 05:38 PM
derherr65
All Things Towing
Feb 27, 2006 12:53 AM
Amphibious CWO
All Things Towing
Nov 13, 2004 07:57 PM
