Help please
Old Sep 24, 2016 | 11:48 PM
Big rizzy's Avatar
Big rizzy
Help please
Okay so I have a 1996 F250 5.8 automatic C6 transmission I think the smog pump froze up so I took the pulley off and put a smaller belt 84,5". While doing the work I decided. To put straight pipes On so. I did sounds great nothing wrong until. I drive away now the truck doesn't shift unless very h rims and slips if I let off the throttle and push again. I didn't put the The o2,sensor back In the exhaust. That the only change I made besides by passing the smog pump...... No check. Lights or anything else
Old Sep 25, 2016 | 09:43 AM
timbersteel's Avatar
timbersteel
If your truck is a '96, then it would bet it is equipped with an E4OD transmission. I don't think C6 was offered after '94.
And with no O2 sensor hooked up, the Check Engine light will be illuminated. That is probably your problem now since the transmission is completely controlled by the PCM. Any sensor problem or malfunction begins a Domino effect.
You need to install the O2 sensor and check for codes.
matt96bronc
1978 - 1996 Big Bronco
Apr 3, 2005 09:56 PM
rmalottwtes30
Mar 23, 2005 07:56 AM
geoaigel
Apr 26, 2003 05:56 PM
CurtisF250
13
Jan 6, 2003 06:02 PM
restorit
Sep 18, 2002 11:45 AM
