Location of ABS control
2009 Ford F350 Diesel
I am trying to find my ABS controller because I have an intermittent ABS light on the dash and the code says something about signal loss on more than one wheel. So I assume I have bad wiring or a loose plug somewhere.
I found this (pic attached) on the left hand side under (or a little behind) drivers seat mounted under truck on the frame rail. I think it is the control module but when I tested wiring I found no continuity to any of the ABS wheel sensors.
Is this the control module?
That would be the HFCM, Horizontal Fuel Conditioning Module.
ABS module is (IIRC) under the hood, driver's side fender wall, in front of the master cylinder, I can't find a clear picture of the area.
EDIT: Hell if I know where it is, I didn't think it moved far but every picture I can pull up of the 6.4L in the engine bay doesn't show it, I thought it was kind of under the degas bottle in front of the junction box but there's a fender support there? I just know that ^^^ ain't it
Page 3 of .pdf shows the HFCM:
Thank you for the reply. I'll take a look but I have looked there before and I didn't see anything.
Question to anyone who knows about this ABS system. Are there two modules for the ABS? One that is purely electrical that controls things and one similar to the picture above that surges the hydraulics?
I am thinking that perhaps what I found is the piece that surges the hydraulics but perhaps the control piece may be somewhere else. That would explain why I got no continuity with the sensor wires. They would go directly to the control module (if there were two pieces).
As always, any help you can provide is appreciated.
ok, thank you both. I'll dig into it. I hope it is only a loose plug.
I hope I didn't make a bad purchase. I just got this truck and after working on it a bit I discovered it had been submerged in mud. Probably up to cab level. So a fine layer of dust covers all electrical connections and anywhere it can get. I keep chipping out caked mud from the underbody and holes in frame rails. I worry this is just the tip of the iceberg on electrical issues.
OK, I found the ABS controller. That didn't help much though. I spent several hours today testing continuity and tracing harness wiring. I don't see any problem spots in the harness yet I am still getting code C1175 which says "left rear sensor signal loss". That is odd since I am sure these only have one rear sensor in the differential.
I am not able to get continuity from the rear sensor (which I replaced) to any wire in the ABS control plug.
Also, I found +12V on one wire to each of the front wheel sensors with the ignition on. Should I see that on the VSS also? I didn't.
It baffles me that I don't see any issues in the wiring yet I don't get VSS signal to the ABS.
In desperation today I pulled and examined each and every fuse from the fuse box in engine bay and in passenger kick panel. No luck there, all fuses good.
Does anyone have any suggestions on what I should be looking at/for? I am stumped.
The following users liked this post:
Abs intermittent light on after reset
av8djc
04-04-2005 07:28 PM
