EEC no timing advance
Old Sep 22, 2016 | 09:10 PM
wrooper's Avatar
wrooper
I have a 1992 F150,5.8l w/E4OD
The last service I did was to replace the MLPS after it's rusty/balky operation caused me to break my shift lever.
Several weeks later [it does not get driven much] it presented with low power,bogging down on throttle.
I have timed it w/SPOUT out at 10 BTDC and it idles fine. Whenever I advance RPM I do not get any timing advance [measured with timing light at the harmonic balancer] As a result it backfires out the intake and falls flat on it's face.
I have replaced the TPS and swapped with a known good ICM [when I tried the ICM it was not grounded so the swap may not be valid but other posts say the ICM only controls timing at idle]
Can anyone give me an idea why I have no timing advance with RPM/load?
BTW I can only start with starting fluid
Thanks Bill
Old Sep 23, 2016 | 04:40 PM
wrooper's Avatar
wrooper
Fixed it by taking out the ECM and replacing the 3 largest capacitors. One was badly burnt and hanging by one leg.
For all the folks who say ECM as last resort it only takes a few minutes to pull it out and inspect it. Wish I had done it first
Old Sep 25, 2016 | 11:43 AM
Glaser67's Avatar
Glaser67
I need to replace mine as well, where did you find the capacitors at? Was it online?
wrreed
27
Sep 11, 2009 10:06 PM
bhardy501
May 12, 2007 07:33 PM
mohavi
Feb 18, 2004 10:41 PM
fordeverpower
Dec 5, 2003 08:21 PM
