05 lariat 4wd engine safe mode!!!!!
where to even start!!!!... i have a 05 larit 4wd about 7 months ago i replaced the motor...2 months ago i started having issues with my hubs i ended up replacing them 5 times before a aweful sound started coming from the rear end. i took it to the same shop where they took my drive shaft out and told me to replace my transfer case. that i can drive it with no shaft till otherwise. i drove it for around a week and could not stand the sound any longer. i purrchased a transfer case and dropped my truck/off with them a month passes and i go up raising hell. they then tell me that they decided to replace my flywheel because they didnt when replaced motor....it apparently was not on right with the tourqe converter causing the first pump in transmission to go.... i then purchased a transmission to be shipped to shop month later (last week) i went and picked it up... Runs like pure **** before i got down thee rd i got engine safe mode, transmissiion malf., and over drive flashing pop up. i called and got told the computer needs to relearn its self. i got home put it on my own computer and it started throwing codes for throttle body.. i replaced it myself and i noticed my pcm was not hooked all the way back up, also my vacuum line from transfer was in back of truck not hooked up placed that back on. drove one day codes went away, then on the way to my kids school house it went into same codes and left me putting home at 10mph...any help????
