Modular V10 (6.8l)
need help
Old Sep 21, 2016 | 01:43 PM
rebelsapphire's Avatar
rebelsapphire
need help
I have a 2002 excursion limited v10. I'm trying to figure out why it's not starting. It ran good yesterday morning, but when I went back out to go somewhere, it won't start. No cranking no nothing. Battery is good, cleaned terminals and checked cables and they look good. Starter is good and even swapped the ignition switch, but still nothing. And help?
Old Sep 21, 2016 | 02:53 PM
Sam I Am's Avatar
Sam I Am
When you say "no nothing" does that mean there are no dash lights at all when you turn on the key?
If so then that would indicate a fusible link is open or there is a bad cable connection somewhere.
If you do get dash lights but no action on the starter motor, that would indicate a bad starter relay. You can jump across the relay to check if it is bad.
Old Sep 22, 2016 | 07:39 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Also, try putting the transmission in Neutral - or just jiggling the shifter while holding the key on START. The switch on the side of the tranny has been known to go, and cause "no crank" conditions.
Boondockdad
Jun 16, 2017 03:49 PM
Littlejon
1997 - 2003 F150
Mar 21, 2016 12:19 AM
makthenif
13
Jan 20, 2014 07:50 PM
dangerranger10
1983 - 2012 Ranger & B-Series
Aug 11, 2011 09:07 PM
Eu07
Bronco II
Oct 15, 2003 11:50 AM
