questions for mechanics
Old Aug 21, 2003 | 05:24 PM
lots o miles's Avatar
lots o miles
After buying dye to tell exactly where my 97--7.3-PSD is leaking oil from I have found out that it is leaking from the front cover of my motor not a easy job but with the $$$$$ that even the international shop has given me I have got to do this myself so My question is that several mechanics have told me that they are not sure if you can just lift the motor up to the turbo on the firewall and remove the front part of the oilpan to drop the pick up tube before pulling the front cover. I take myself as a pretty decent mechanic and in the three books that i have over this motor -none of them tell you that you have to pull the motor even !!! but only two mechanics say they have went this far into it --even the lead tech at the ford house here hasnt done this and doesnt have a clue either!!LOL so you see my delima thinkin maybe someone can help
Old Aug 21, 2003 | 06:21 PM
Ggg6's Avatar
Ggg6
I have not done a front cover in our chassis before, just on the IH chassis. I think your chances will be better on a 2wd v/s a 4X4. Worse case senario, you loosen the turbo and move it to the side and get a little more room, or remove it. Either way it takes about 1/2-3/4 hour.
Old Aug 22, 2003 | 12:29 AM
lots o miles
Anything to really be watching for when I go to lift it up besides this? Since the high pressure oil pump(HPOP) is gear driven does it need to be timed when i go to put it back together? Thanks for all the help guys going to tear into it tomorrow --309,000 and shes never had oil leak like this
BryanStein
Oct 21, 2013 11:51 PM
fightlivefree
18
Jul 27, 2013 02:17 AM
Billyclub
25
Aug 21, 2009 06:48 PM
chellbe123
1983 - 2012 Ranger & B-Series
Jul 13, 2004 01:07 AM
1981F150
Oil & Lubrication
Dec 7, 2002 11:56 AM
