How many?
Old Sep 19, 2016 | 08:16 AM
Vinford's Avatar
Vinford
How many?
Just got my 2016 and was wondering if it has 2 turbos or one?
Does it have 2 alternators?
My 2008 had 2 of both.
Old Sep 19, 2016 | 08:24 AM
Spamfritter's Avatar
Spamfritter
2011-2014 6.7L diesel engines are equipped with a Garrett/Honeywell GT32 sequential turbocharger. They are essentially two turbos in a single package. The smaller turbo feeds the larger one. The 2015-2017 6.7L engines use a single Garrett/Honeywell GT37 variable geometry turbocharger. It's a single 88mm unit with vanes or fins that adjust to alter the flow of air to mimic a smaller turbocharger when power is needed quickly. You have two options for alternators I believe. One is a single heavy duty alternator (most common) and the second is dual alternators.
Hope that helps.
Old Sep 19, 2016 | 08:30 AM
Vinford's Avatar
Vinford
Hope that helps.
Thanks Ill have to find my sheet and see about alternators
Old Sep 19, 2016 | 08:48 AM
Painted Horse's Avatar
Painted Horse
Wasn't there also a single regular duty 157 amp alternator that was the base standard alternator, as well as a single Heavy duty 200 amp alternator.
The Dual which was the combined 157 amp and the 200 amp for a total of 357 amp.
You got the heavy duty alternator if you got the Rapid Heat option.
Old Sep 19, 2016 | 09:21 AM
EO2SeaBee's Avatar
EO2SeaBee
Hope that helps.
Not terribly important to the OP since he is asking about a '16, but the turbos on the 11-14 are not actually sequential as they were on the 6.4 PSD. It uses siamese compressor wheels to allow use of smaller wheels for faster spool up. There were some advantages and disadvantages to this design, but the '15+ turbos seem to have addressed several of the issues associated with the siamese used before.
Old Sep 19, 2016 | 04:27 PM
Dakster's Avatar
Dakster
Three alternator options, regular, HD, and Dual. Some options require at least the HD. I like my duals with the rapid supplemental heat option. Hopefully it puts less stress on them and the batteries.
'17's they added dual heavy duty as an option as apparently even duals with a regular and HD alternator were not powerful enough.
Old Sep 19, 2016 | 09:08 PM
Vinford's Avatar
Vinford
Yup I have rapid heat.
Old Sep 20, 2016 | 08:12 AM
Spamfritter
I've never seen a diesel truck without the heavy duty or dual alternator options. I'm not saying they don't exist, but I haven't seen one and therefore didn't think to mention that. Now that I think about it, the build configurator on the website does let you build the truck that way.
Old Sep 21, 2016 | 01:15 AM
Dakster's Avatar
Dakster
Spamfritter - Honestly, I can't imagine anyone wanting the regular, single, Alternator on one of these trucks... Maybe a fleet XL trim truck with no options and one that will never tow anything and being ordered from a company (or government agency) that pinches every penny.
BIGTRUCKBIGRV
Mar 2, 2021 06:12 PM
TAT2DUP81
Mar 2, 2018 02:15 PM
slownsy
Apr 27, 2016 05:06 AM
Green96
Jan 3, 2014 12:51 PM
a64armt
6.4L Power Stroke Diesel
Jun 13, 2008 02:47 PM
